For Sale/Looking For
Parts for Sale/Wanted
New Sachs clutch w/install kit, trans, waterpump, Bentley
Topic: New Sachs clutch w/install kit, trans, waterpump, Bentley (Read 4391 times)
February 09, 2009, 02:48:11 pm
Spulen81
February 09, 2009, 02:48:11 pm »
New in box 200mm Sachs clutch kit. Will fit and A1 or A2 with a 200mm clutch.
SOLD
Comes with:
-alignment tool
-thrust plate and retainer clip
-input and pushrod seal
-pushrod bushing
-crank bolts and PP bolts
-throw out bearing
AGS 5 speed, has .75 fifth. From a diesel but ratio wise it would work fine in a gas car. I have to verify the code but I'm pretty sure. $150 pick up only
New Graf waterpump, the good kind. $SOLD,
MK2 Bentley $SOLD
'86 4Runner TDI SOLD
'91 GTI - TDI converted
February 09, 2009, 08:14:42 pm
Dakotakid
February 09, 2009, 08:14:42 pm »
Are you parting out an '86 car by chance? Are you letting go of the fuel pump?
February 10, 2009, 06:44:28 am
Spulen81
February 10, 2009, 06:44:28 am »
I am actually. Make me an offer on the injection pump I'm not sure what they are worth. The car was running fine, the PO changed the t-belt and wiped out the valves. Its only been sitting for a couple months.
February 10, 2009, 10:24:27 am
Dakotakid
February 10, 2009, 10:24:27 am »
PM'ed ya, I did.
February 10, 2009, 11:13:51 am
GIDDY_UP_GO
February 10, 2009, 11:13:51 am »
How do you know if you have a 200mm clutch or not? I have an 86 Golf N/A Diesel with a 5 speed.
Also, what shape is the Bentley in?
86 MK2 Golf Diesel
February 10, 2009, 11:31:20 am
Spulen81
February 10, 2009, 11:31:20 am »
You *should* have a 200mm, this kit was for an '86 diesel also. Unless somebody swapped it out for a 210 at some point. The Bentley is in good shape. Its used but not super dirty or worn. I can email you a pic if you want, just PM me you email address.
February 26, 2009, 05:38:42 am
Spulen81
February 26, 2009, 05:38:42 am »
Bentley and waterpump are sold.
March 16, 2009, 08:56:01 am
Spulen81
March 16, 2009, 08:56:01 am »
Only the trans is left. It is an AGS for sure also.
