Author Topic: Rear Discs brakes from a corrado onto an MKII?  (Read 7849 times)
Reply #15February 22, 2009, 11:45:51 pm
Torchd
  • 372
« Reply #15 on: February 22, 2009, 11:45:51 pm »
hmm...  So that tells me the rear beam is same on both the cars..
Reply #16February 23, 2009, 05:07:12 am
« Reply #16 on: February 23, 2009, 05:07:12 am »
Could be, could also be that just the bolt pattern where the brakes bolt to the axle are the same. the Passat is prob going to be wider that a jetta, GTI, Golf or Corrado?
Reply #17February 23, 2009, 07:26:10 am
foxracer1
  • Authorized Vendor
  • 991
« Reply #17 on: February 23, 2009, 07:26:10 am »
The passat rear axle will be wider. Should be similar to the Jetta III rear axle. It will most likely have a torsion sway bar built in to the beam.
Any 4 lug rear disc brake set up will bolt in to your car.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #18February 24, 2009, 12:43:53 pm
Torchd
  • 372
« Reply #18 on: February 24, 2009, 12:43:53 pm »
Rite. Thanks foxracer
