Diesel newbie need some help!
by
Clintwalker85
on 17 Jan, 2009 22:54
ok so heres the deal....i just bought a 1994 vw golf 1.9 turbo diesel i have spent soo many hours on this site reading up...now i just orderd a pyrometer and i don't know where to install it on the 1.9...thats issue no.1
no.2 i orderd a straight muffler...got rid of the cat converter and going to take both res and muffler off..after thats done i would like to tune the injection pump but i can't find the ajustment screw all you ppl are talking about..? if someone could helpme out that would be great! is there any good pictures or video's of anyone ajusting the screw? thanks!
#1
by
Rabbit TD
on 17 Jan, 2009 23:38
I don't know what your manifold looks like but the best place to put them is right under the turbo where all 4 cylinders exhaust is converging, in other words if you take the turbo off you want to see the probe down there looking at you. And do yourself a favor and take the manifold off to drill it and tap it. I can't imagine tapping it on the car as some say they have done, it took me about 1/2 hour just to tap it with the 21/64 hole and I was scared the tap was gonna snap at any monent and it is a good tap and it gets tighter the further you go because of the taper. Did you get the spruce thermocouple, they are supposed to be really fast reading, I got one and am waiting for the Autometer SportComp gauge to get here to match the boost gauge I already had from a truck I had. I don't have any experience on turning the screws yet so I'm not saying anything about that.
#2
by
Clintwalker85
on 17 Jan, 2009 23:45
thanks, its an autometer phantom, trying to find a boost gauge to match...dam ebay its always 1 gauge or the other never both...
#3
by
Dirtrag2
on 18 Jan, 2009 03:52
first off read the post on how to make your TD a faster car... no more pics but still pretty informative.
looking at the pump from the front, the fuel adjustment screw is on the right side just beneath the LDA it has a plastic cover on it ( probably red ) and a metal ring holding it in place. carefully break them off and voila you have access to the screw.
hope this helps :wink:
#4
by
Clintwalker85
on 18 Jan, 2009 09:23
thanks i'll have to check that out tonight! can't ajust yet tough...still waiing for the exhaust to come in :roll: gotta watch those egts..
#5
by
Clintwalker85
on 18 Jan, 2009 19:56
ok so i was looking at the "make your td faster" i was reading it but none of the pictures are there so when it says screw #1 ect i have no clue anyone have those pictures and what not that were soposto be on that thred? or can some one make pictures for me?? it would be a great help!!
#6
by
dillenger1
on 19 Jan, 2009 03:07
Its the screw behind and under the "out" bolt(fuel return).theres a collar on it that needs to be tapped off with a drift.
#7
by
Clintwalker85
on 19 Jan, 2009 10:58
can i ajust that screw with the factory exhaust on it or should i wait to put the aftermarket exhaust on i just don't want the egts to get too high i already installed a cold air intake on it so it will breath better but will that cause higher egts with the factory exhaust?
#8
by
Clintwalker85
on 20 Jan, 2009 19:03
ok so i was looking at the injection pump...i found a screw woth a hole threw the side of it....there was no "red plastic cap" on it but it does have a red insert its just above the injector fuel lines....i took some pictures can someone tell me if this is the right screw?? i don't know how to add pics but i can e-mail them to anyone that can tell me..
#9
by
Rabbit TD
on 20 Jan, 2009 21:20
I just got my Autometer Sport Comp Pyrometer and water temp gauge today in the mail. I wanted to do the torch test this evening but I didn't feel like taking it back out of the manifold to see how these spruce probes work. Motor isn't in a car yet
P.S. Did you try Summit Racing, they're prices are pretty good if they have the one you want. I got mine at Egauges.
#10
by
regcheeseman
on 21 Jan, 2009 02:22
I've got the thread and snippets of others stored in on one word .doc file complete with pictures.
Can email to anyone that wants it - just pm your email address.
Maybe it's worth hosting on here - as many ask for it?
