how does this turbo map look?
by
monomer
on 11 Nov, 2008 20:54
For a 1.6td build (turbo bottom end, 8v turbo log mani - 38mm wastegate)
#1
by
monomer
on 12 Nov, 2008 15:07
none of the turbo guys are gonna chime in?
#2
by
jackbombay
on 12 Nov, 2008 15:53
The pressure ratio is not particularly high, above 3 is what you should be looking for.
Is the X scale cubic meters? Do you have a higher res image of the map?
If you can confirm what the X scale is I can plot a few points on the map for you.
#3
by
monomer
on 12 Nov, 2008 17:32
thats a screendump from a pdf
anyone know where to host a pdf?
Volumetric Flow m3/min is labeled on the bottom
#4
by
flapjack
on 14 Nov, 2008 11:55
#5
by
monomer
on 14 Nov, 2008 13:04
sent
#6
by
flapjack
on 14 Nov, 2008 13:47
click for
TURBO PDFand here is a slightly better screenshot of it
#7
by
monomer
on 17 Nov, 2008 18:07
any better?
#8
by
monomer
on 19 Nov, 2008 15:00
^ANYONE?
#9
by
on 19 Nov, 2008 15:05
Drop jackbombay a PM. He's pretty good with maps.
#10
by
Jet A
on 19 Nov, 2008 15:53
Id run it.
Should have plenty of range for your motor.
#11
by
monomer
on 19 Nov, 2008 17:33
Id run it.
$300 NEW...
#12
by
blkboostedtruck
on 19 Nov, 2008 18:57
i've ran one but on a gasser! it is a quick spooling turbo!
but i don't think the turbo's last very long? when i got my truck it had one on it! and it also had 3 trashed core's with it for parts! and even the one that was on it took a dump! so i redone the manifold so it would fit a K26 and i never had a problem since!
Duane
#13
by
monomer
on 20 Nov, 2008 14:03
Duane
hmmmmm, my other garrett has lasted 400k miles
sounds like you have problems...
#14
by
on 20 Nov, 2008 14:06
That goes without saying! :lol: :lol: :lol:
