Folks,
The 90 Jetta's climate control blower motor has bit the dust, along with the resistor. It
had factory air (everything is gone except the compressor which is free-wheeling for now). Are the physical
mounting dimensions the same for any of the flavours of blowers out there? The replacement motor from any reseller for the ones with factory air is almost worth as much as the car. Tough to find at the pick'n'pull too....
Here's the setup I have:
and here's the blower without factory air, and 1/4 the cost....
Andy
I don't see any mounting holes in the Non AC version.
Then is there clearance from the rear of the motor so it wont hit the dash?
Maybe you could swap the motor and keep your housing then use the resistor as well?
They are not the same. The ac one screws in, while the non ac one just turns in with it's own cam locks.
try big_b on vortex. He has lots of mk2 parts. The diesel and gas stuff is the same as far as I know. You could swap to non AC under the dash
i think i got a couple kicking around here?
witch one you want the one in the top pic?
Duane
Well, I found some of these AC puppies when I went to visit family, and I discovered something when I went to mount it that I didn't see when I pulled the old one out...(it was dark out)...
It appears the motor was operated on full blast a lot, because the bottom of the cut-out in the ducting was seriously "rubbed" allowing the replacement to wiggle a lot. it wore away so much plastic there's a gap at the bottom and the new one does bolt up...but the bolt holes are now "slots". It allowed the blade to actually rub on the bottom backside and wear away a good deal of the outer section of the "blade".
Nothing a few blind nuts and some epoxy won't fix, but what a PITA.
Andy
