General Information
Troubleshooting
Need some advice
Topic: Need some advice (Read 3883 times)
August 04, 2008, 03:28:53 pm
cube1980
User+
Need some advice
August 04, 2008, 03:28:53 pm »
Getting some noise which sounds like the rear drivers side of my Golf. It's not present all the time but seems to happen if I go around a corner and the car hits a bump at the same time. It's like a clunking sound only when I hit bumps going around a corner. Does this sound like the rear struts???
Also wondering if anyone has had any trouble with their cruise control. 1996 Golf 1.9TD.....works sometimes and other times it doesn't work at all. Could it be a bad connection?
Thanks in advance
August 06, 2008, 08:54:21 am
DieselSteed
Need some advice
August 06, 2008, 08:54:21 am »
Sounds like it might be strut mounts.
When my lady really wants to get me in the mood, she rubs a little diesel behind her ears.
August 06, 2008, 03:28:37 pm
cube1980
User+
Need some advice
August 06, 2008, 03:28:37 pm »
Rear strut mounts could be the possible noise? I'm guessing I'll have to take everything off...might as well replace the struts while I do it?
Thanks for the reply
August 06, 2008, 06:57:47 pm
cube1980
User+
Pressure Regulator
August 06, 2008, 06:57:47 pm »
I got under the car tonight and noticed the rear brake pressure regulator is loose and I'm thinking this might be the noise I'm hearing. Does anyone know if it is supposed to be loose or how to adjust it??
August 06, 2008, 08:38:47 pm
Need some advice
August 06, 2008, 08:38:47 pm »
the rear strut mounts are more like rubber bump stops... not much too them, but i suppose they could crack and make some sort of clunking?
AFAIK the rear brake proportioning valve shouldn't be 'loose' :lol:
General Information
Troubleshooting
Need some advice
