Ok, may have found the problem. It looks like somewhere on the oil filter flange is leaking. See below.
I had to come in cause of the heat for a little while, i'll head back out an run her again and check it some more. Is there a gasket behind that flange? Could the high pressure sensor be leaking. Can't really tell yet.[/img]
Found it. The sending unit for the pressure sensor is leaking out the top. To be replaced soon. Thanks for the help yous guys!
why not just tighten it?Dont use any tef tape it will isolate the ground.
I don't know if these VW senders will do it or not but I've seen some others leak internaly right through them and out around the pastic at the connector.
