when changing to a 1.6TD pin do i use the spring as well?
Topic: when changing to a 1.6TD pin do i use the spring as well? (Read 2951 times)
April 05, 2008, 06:33:48 am
James8485
April 05, 2008, 06:33:48 am »
i changed the pin in my aaz to the 1.6TD i changed the pin and spring so its got the shorter stiffer one in there now did i do this correct or should i have just done the pin and left my biger one i there, i heard if you leave the bigger one in it will go into full fueling boost with like 4 PSI?
any comments you guys?
---------James--------
April 05, 2008, 09:38:39 am
Possum79
April 05, 2008, 09:38:39 am »
I think i remember jimfoo saying use the spring other wise it defeats the purpose.
1979 VW Rabbit Diesel L
My car may be ugly but im addicted to it.
April 05, 2008, 01:42:16 pm
gldgti
April 05, 2008, 01:42:16 pm »
no, you dont need to. just change the pin and diaphragm over, the old spring will work (i did it on my 1.9TD, big difference hehe)
'91 Golf Cabrio 1.9TD
April 05, 2008, 05:35:56 pm
April 05, 2008, 05:35:56 pm »
Well it depends on if you want the LDA to work like it is supposed to, or just go to full enrichment as soon as you get to 4-5 PSI, which is what the AAZ spring will do.
April 05, 2008, 07:59:56 pm
Dirtrag2
April 05, 2008, 07:59:56 pm »
so jimfoo, if I am running 15psi should I use the 1.6 spring or not :?:
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
April 05, 2008, 08:41:56 pm
April 05, 2008, 08:41:56 pm »
I would. If I remember right, it gives full fuel around 10 psi or so, way better than 4. I think ideally, it should be matched to your max boost, but it would be hard to find the right spring.
April 05, 2008, 11:10:22 pm
DonGTI
April 05, 2008, 11:10:22 pm »
Jimfoo if i keep the stock K03 with no wastegate alterations/settings and which in itself is not a turbo that likes to blow too much psi, what would you reccomend? i wasn't even going to adjust anything regarding smoke screw ecc, just replace pin... would it be more practical if i use the aaz spring so i don't pull too much boost or replace spring and buy a boost gauge?
Fast and Cheap is not Reliable
Reliable and Cheap is not Fast
BUT
Reliable and Fast is NEVER Cheap...
- someone's wise words after my GTI engine died -
April 06, 2008, 10:53:27 am
James8485
April 06, 2008, 10:53:27 am »
i am running the stock K03 turbo on my AAZ and i have replaced the spring and pin and it works really well not to much smoke but way more go! since the k03 boost like instinly i get that low end torq right away i switch through gears at like 2200 it shoots me up to speed really quick!!
i am running the pin at about half
as for the turbo i have played with the waste gate a bit and even when the screw is slmost to the end of the rod i have never gone over 15 PSI
i have a boost gauge and the only way i have seen more is to pinch the other line coming off it. (sees like 20-25) didn do that for more than 5 min though!
April 06, 2008, 01:27:12 pm
DonGTI
April 06, 2008, 01:27:12 pm »
your boost gauge has 2 lines? which line did you pinch? the wastegate line me thinks
BUT
April 06, 2008, 02:06:09 pm
April 06, 2008, 02:06:09 pm »
5 mins at 20-25 psi :shock: :twisted:
