#15
by
burnt_servo
on 30 Mar, 2008 14:12
#16
by
numbnuts
on 01 Apr, 2008 04:45
So its the 1.6 td T3 i should be looking out for then?
#17
by
stewardc
on 01 Apr, 2008 11:44
Yessir, that's the one.
#18
by
raf_construct
on 01 Apr, 2008 11:49
You can also find a k24 from a mk2. They are a bit better than the T3 at higher boosts.
I am custom fitting a GT1749 to my 2.1 AAZ engine. Will post any feedback here when it's running.
#19
by
stewardc
on 01 Apr, 2008 11:52
Beg to differ here. I tried em both and the T3 is the answer. Now to button down the hatches for the innevitable flamers. :roll:
#20
by
James8485
on 01 Apr, 2008 13:31
i just gots a k24 and intalling it in the next couple days! what wrong with the k24 i heard its an awsome turbo perfect size spools up good and has good boost
whats the diffenence between the 2?
#21
by
raf_construct
on 01 Apr, 2008 14:20
They are practically the same, they are both very good at handling high pressure. If both were to be pushed to the limit, the T3 usually breaks down just a bit faster. However, not many take it that close to the limit. :wink:
#22
by
bert
on 01 Apr, 2008 14:44
the garrett parts are easier to get hold of...........
my garrett T3 is an amazing piece of kit,well pleased with the spool up and the boost :wink:
#23
by
James8485
on 01 Apr, 2008 15:26
the T3 isnt the same triangular flange as the the aaz K03 is it>>>
i went and got a k24 b/c i could find any good turbo to direct bolt
#24
by
Torchd
on 01 Apr, 2008 23:56
Which car/engine were the following turbos originally fitted on?
K03
K14
Garrett T3
K24??
#25
by
ChopSauce
on 02 Apr, 2008 02:30
K03
K14
Garrett T3
K24??
In France
K03 -> AHU, possibly 1Z (1900 TDI) (1)
K14 -> two models - small (2) on RA/SB (1600 TD 80 ch) - larger on AAZ (1900 TD)
Garrett T3 -> JR (1600 TD 70 ch)
K24 -> JR and similar (1600 TD 70 ch) engine on Mk1
_
(1) Only the K03 and the GT15 turbos seem to have that triangular "bolting pattern" - on the exhaust manifold, while the other turbos above seem to have the same (T3-like) bolting pattern
(2) The "small" K14 appeared to be (sometimes) replaced by a T2 - same as K24/T3 - note : there seem to be more T3 and K14 here
#26
by
Torchd
on 02 Apr, 2008 23:06
Thanks for the info ross!!!
So which turbo will i have on my cars??
MKII, 1989, 1.6TD.. Engine MF.
MKIII, 1996, 1.9TD.. Engine AAZ.
#27
by
ChopSauce
on 03 Apr, 2008 01:16
You're welcome, but I do not know anything about the MF engine (only JR & RA/SB). How many Hp(ch) is it ?
80 ch is either equipped with a T2 or K14 - most likely watercooled, otherwise that is T3/K24 - normally. If it is 1989 it is probably a JR - with a T3. Is the turbo a Garrett ?
... and, er ... I thought that was written above: the AAZ is normally equipped with the larger - oilcooled - K14.
As far as I know all that is written on the turbos - but the nature of the cooling ... of course
#28
by
raf_construct
on 03 Apr, 2008 04:04
Later AAZ engines can also have a k03 turbo. Usually combined with an EGR system.
At least in Europe this is.
RA/SB engines can have a non-watercooled turbo as well. This is mostly the k14 I believe. Haven't seen them with the bigger k24 / T3 turbo's yet.
Watercooled turbos are the k14/6 and the garret T2.
#29
by
Torchd
on 03 Apr, 2008 04:24
John its a 70 hp engine... and the turbo is by KKK
