02J Tranny with Peloquin Differential
by
subsonic
on 28 Mar, 2008 07:28
#1
by
on 28 Mar, 2008 13:34
how hard is it to install an 02J into a mk2?
#2
by
subsonic
on 28 Mar, 2008 15:18
I saved a link I found on that exact question. It had a detailed write-up, what parts you needed, part numbers etc... It is on my computer at home. From what I remember, you need different motor mounts, a hydro clutch or cable operated clutch set-up. cable operated shifter system. A different speedo gear. etc.. I will try and find the link again. It looks to be almost the same as a swap for a 02A.
#3
by
RabbitGTDguy
on 28 Mar, 2008 15:55
02a 02j into a MK2 is straightforward...a matter of mounts and parts. Thats it. Mk1 is where it is more difficult. There is lots of information out there but really...its almost "bolt in"
Joe
#4
by
on 28 Mar, 2008 21:24
thats for sale in york, pa, which is where i live
#5
by
subsonic
on 28 Mar, 2008 22:06
Joe
Got a run down on those parts? I was wondering what the additional parts would run? I thought I read somewhere that the fly wheel for these was pretty expensive-dual mass?
#6
by
on 29 Mar, 2008 01:53
it has a nice tall final drive too... might be acceptable on a diesel
#7
by
RabbitGTDguy
on 29 Mar, 2008 09:26
'rado or passat style clutch/accel pedal assembly, master/slave bracket from 'rado/passat, clutch master, clutch slave, b3 or 'rado front tranny/motor mount. Cable shift box with cables. then its the installation from there. MK2 has the holes in the firewall for mounting the bits... the biggest part of the install would be the cable shift box and removing the old linkage style setup, etc.
Flywheel isn't an issue. Any 'rado/b3 16v one will work nicely as long as it does not come from a VR6.
Joe
#8
by
subsonic
on 29 Mar, 2008 11:01
Is it true you can also go the route of a manual clutch cable? I thought I read a g60 flywheel would work as well.
Have you done a swap like this before?
#9
by
RabbitGTDguy
on 29 Mar, 2008 14:32
Yes...you can get the euro clutch cable setup for the 02a...then there are a variety of items that you do not need...
The g60 flywheel is the "rado" flywheel I was talking about....from a corrado g60. It is the same as the 16v passat flywheels as well. Common upgrade for the TDI's as well.
Yes...I have done this swap 3 times now and a auto to standard swap in my 'rado as well.
Joe
#10
by
subsonic
on 31 Mar, 2008 15:45
Sent the seller a email today. He who hesitates is lost. He thinks he as a buyer :cry:
#11
by
on 31 Mar, 2008 16:33
i plan on doing an o2j swap eventually haha, or o2a i don't care which.
#12
by
subsonic
on 31 Mar, 2008 19:01
Are you the buyer he has lined up?
#13
by
Justin
on 04 Apr, 2008 06:50
the swap into an MK1 is pretty straight forward, Mine is a little bit of a hack job but it was pretty easy, keep your axles and get 100 mm cvs, different trans mount (or modified 5 speed ff mount in my case) different clutch and pressure plate set up, modified rear trans mount and the cable shifter box bolted in, the biggest thing is getting the clutch hardware and cable shift box for the right trans, I had a VR6 box at first and has a different pattern so I didnt have reverse.
love the cable shift over the old linkage.
later
jkeiffer
#14
by
subsonic
on 04 Apr, 2008 07:29
It appears that the swap into the mk1 is a bit difficult. The mk2 should be easier. I am hoping that someone who has done this swap in the past, or has good knowledge of it will do up a "How To" in the FAQ section. It looks like a very good upgrade if you are going to be pushing quite a bit more HP over stock. I will look online and see if I can get a parts list and poss. part numbers for the swap. It will be a start.
