solar panel blowing fuse
by
cory
on 31 Jan, 2008 15:45
I have a VW Solar Panel that I have been using for the past few years to keep my battery topped up in the cold winter months.
Recently is has started blowing the fuse whenever I plug it in.
Anyone have any input on why it may have started this new trick and/or what I can do to remedy the situation ?
Thanks
Cory
#1
by
on 31 Jan, 2008 15:52
contacts shorting out? is it all corroded? i would try other things in the cigarette plug to see if they blow the fuse a well. if not then its your solar panel :wink:
#2
by
cory
on 31 Jan, 2008 16:36
The contacts are in great condition. My cell phone charger doesn't blow the fuse...but it is drawing current not feeding it. That seems like it would make a difference but I am not sure. My first thought was that the panel was faulty but I couldn't reason why it would fail out of the blue.
#3
by
MaxHedrm
on 31 Jan, 2008 17:27
Too sunny? That's really weird. I would imagine in order cause that it would have had to have shorted or something.
#4
by
on 31 Jan, 2008 18:12
does it blow the fuse right away? what rating is the fuse?
#5
by
cory
on 31 Jan, 2008 21:10
It does blow right away. It is a 15 amp fuse. The radio works fine, which is on the same circuit. Plug in the panel and...done.
#6
by
on 31 Jan, 2008 22:03
Probably a short in the cord or plug.
#7
by
BlackTieTD
on 01 Feb, 2008 07:41
ya a short in the solar panel electrics
#8
by
Darkness_is_spreading
on 01 Feb, 2008 11:52
It will be one of two things..... Check the continuity of the cables, then check the input to the board, there will be a zener diode or voltage regulator, and in this case you may have an internal short. Connect a scope to the ouput of the solar panel and see how clean the signal is, or measure the output with a volt meter, it should stay constant, then add a load (under rated load of solar panel) and see what the voltage level is at.
#9
by
bigblockchev
on 01 Feb, 2008 18:03
I say short in the plug itself. Does the solar panel actually produce voltage, check the output with a volt meter. I'm not sure but I think the panel doesen't have much electronics associated with it maybe a diode maybe not. Just DC output and not much of that a few watts maybe 500ma to 1A output current in bright sun. Not much help in charging if it blows fuses. Cheers Dan
#10
by
silvertdi
on 01 Feb, 2008 19:53
That's really wild. I guarantee that solar panel is not putting out greater than 15 A. Probably a few milliamps. Is the wiring to the fuse box stock, or has it been spliced into?
#11
by
cory
on 04 Feb, 2008 08:44
I appreciate all of the insightful responses I got with this issue. Yesterday while I was waiting for my wife to fill up our growler at the brewery I thought I would see if the cigarette lighter would replicate the issue. So I popped in a new 15 Amp fuse and while I was grabbing the lighter from its typical home in the ashtray, I noticed a strange shine in the bottom of the cigarette plug.
I poked a pen down inside for further investigation and got some pretty sparks. I grabbed my flashlight for better light and could see that a small key ring had fallen down into the hole and was seated nearly perfectly at the bottom of the plug. I tried again with the pen to get it out, more sparks and another blown fuse. After the fuse went I grabbed the ring and inspected it. It had 4 burn marks on it...funny that is the number of fuses I had gone through.
Anyway just wanted to let you all know, problem solved. Thanks again for all the input. It was an internal short, of a bizarre variety.
Cheers
Cory
