Low Sulfur Diesel
by
Dieselumbrado
on 26 Jan, 2008 12:51
Today I went by a gas station and saw a diesel pump that says Low Sulfur Diesel, 500 PPM, and was a warning saying: " This diesel is prohibit on 2007 and newer engines".
Is this the old diesel?
#1
by
Quantum TD
on 26 Jan, 2008 17:02
Yep. The new diesel is 15ppm. If you can find it, use the old stuff. Less liklihood of a leaking pump, if you haven't resealed it yet.
#2
by
trent77
on 26 Jan, 2008 20:41
ya,
they have both at my local station, I have been opting for the low, not ultra low. it seems to be working well.
#3
by
vegfuel
on 26 Jan, 2008 21:05
Yeah I am pissed off with this ULSD. I don't know where to find LSD. You would think that they would supply it for all older model diesels.
Guess they never figured an old 79-81' diesel rabbit would last this long! :twisted: thanks to good ol' high sulfur diesel.
Question: what can you do if you have to use ULSD but don't want to blend biodiesel because of sub-zero temps? Any certain additive?
#4
by
1985JettaTD
on 26 Jan, 2008 22:00
most truck stops still have it for the off road equiptment, at leat in canada. it is illegal to use it, but that is only if you get caught
#5
by
Quantum TD
on 26 Jan, 2008 22:09
Age old diesel buffs swear by Stanadyne. I spoke with a diesel tech here in the US who claimed that he's pulled apart pumps on newer cars that looked like they were sandblasted inside. He recommended Stanadyne to prevent wear on the pump. I'm not sure how it does in cold weather, but as you note, if it's warm enough, go with the bio-blend.
The strange thing that I noticed on my GFs 2001 TDI, is that the new ULSD smells really bad when it's run: like burnt hair. But with the Bio-blend, it doesn't smell at all really.
#6
by
vegfuel
on 27 Jan, 2008 00:21
If only there was some secret under-the-table additive that you could use to turn red dyed diesel to a mellow-yellow!
Just maybe...................... :twisted:
#7
by
on 27 Jan, 2008 04:17
some guys have added two stroke oil with some success in stopping the pump from leaking (and it adds lubrication to the pump & upper cylinder too!)
#8
by
TedV
on 27 Jan, 2008 08:51
Power Service also has several additives available. Most common at parts stores, truck stops, wal mart, etc are winter anti gel and summer cleaner, cetate boost that both help lube the pump.
#9
by
eightyonerabbit
on 27 Jan, 2008 09:35
that's what ive been using, and its been working for me... i know that it adds quite a bit of power and increases fuel mileage a little bit...
#10
by
935racer
on 27 Jan, 2008 11:02
Find some hippies, I am sure they could help
#11
by
OM617
on 28 Jan, 2008 05:18
Get used to it. By 2009 ULSD will be your only choice.
#12
by
subsonic
on 28 Jan, 2008 06:12
#13
by
vegfuel
on 28 Jan, 2008 10:17
#14
by
njj_502
on 28 Jan, 2008 16:20
I've been using Stanadyne Performance Formula. Have been running it since I picked up my Golf with no leaks. That's about 20K miles and ULSD 95% of the time. Guy I work with at Cat is a big VW nut and swears by it.
One note tho, there are two different types of this additive, one for pre 07 and one for post 07. I was told by the fuel systems shop where I buy it that the post 07 formula contains no sulfur where as the pre 07 does. Comes out to about $1 per fill up.
