I need one of these(with the check valve if possible) so that i can get the heater working properly in my car.
I am also looking for a grille for the same year Jetta.
Thanks!
jz
do you have a picture of the vacume pump your looking for?
I might just have one, show in the pic the heater check valve, yeh
Unfortunatley, I don't have a pic... The mechanic that is working on my car said that the orginal was removed...
From what i understand it is simply a vacuum resivoir used to hold vacuum pressure so that the bellows in the heating system work more quickly...
If anyone has a better knowledge of how the vacuum system works in an 85 Jetta and wouldn't mind chiming in i would appreciate it.
jz
I just need a picture because I have two different ones here both are brand new.....
thanks for your time
