General Information
Troubleshooting
Dying Rabbit, please help
Pages:
Topic: Dying Rabbit, please help (Read 7025 times)
Reply #15
January 02, 2008, 12:17:41 pm
vegfuel
Reply #15 on:
January 02, 2008, 12:17:41 pm »
Well I finally got it to crank over faster. One of our friends is a logger and had owned many diesel engines and worked on them. Once I told him that I advanced the timing on pump, he suggested that I back it off. The engine was turning over way too hard he said. So I retarted the timing (pump was almost up against one of the fuel pipes!) and cranked it over. It cranked over alot faster but still wouldn't fire. I also tightened the timing belt as it had stretched for some reason and was ready to fall off.
I don't know what to do now as I have replaced the ground wire and installed a brand new terminal. Engine cranks over alot faster and longer now. I still need to do a compression test and test glowplugs. I pulled one and it had engine oil on it :?: . There is lots of fuel getting to the injectors.
Ever since I installed a 5spd tranny from gasser Rabbit it has had problems like this.
1986 Golf WVO converted.
Reply #16
January 02, 2008, 05:23:05 pm
Reply #16 on:
January 02, 2008, 05:23:05 pm »
Quote from: "vegfuel"
if i'm not mistaken the starter receives its ground from the transmission? did you run a fat ground straight to the tranny?
also what CCA is the battery? some places are stupid and sell you the gasoline rated battery :roll: recommended battery for these diesels is a 1000 CCA battery.
Reply #17
January 02, 2008, 06:24:53 pm
vegfuel
Reply #17 on:
January 02, 2008, 06:24:53 pm »
The ground connects to the tranny mount on the driver side and also to the car body. I just went to Wal-Mart and used the computer to find out what battery to use. It had Volkswagen Rabbit 1.6 but it did not specify diesel or gasser. diesel most likely.
Reply #18
January 02, 2008, 07:20:32 pm
Doug
Reply #18 on:
January 02, 2008, 07:20:32 pm »
The battery that you want is a Group 41.
Pages:
General Information
Troubleshooting
