General Information
Troubleshooting
IP won't budge
Topic: IP won't budge (Read 5222 times)
December 18, 2007, 10:45:26 pm
vegfuel
IP won't budge
December 18, 2007, 10:45:26 pm »
So I am in the middle of timing my rabbit 1.6na but I need to adjust the timing. I keep loosening more bolts holding the pump including the ones mentioned in the manual but the pump move
. I don't want to have to tap on anything which is usually the last resort. Is there some secret bolt that I forgot?
1986 Golf WVO converted.
December 19, 2007, 12:19:48 am
Quantum TD
IP won't budge
December 19, 2007, 12:19:48 am »
There are two bolts on the passenger side (one on the either side of the top). There is one NUT on the passenger side (lower center). In order to loosen it, the pump has to be at TDC so that you can slide a 13mm deep socket thru the cam sprocket and onto the nut. Then, there's one last bolt on the lower right corner (driver's side) of the pump. It bolts thru the cadmium-plated bracket that mounts to the distribution head.
If all 4 are loose, and the pump wont' move at all, then tap on it lightly with a rubber hammer.
Let us know how it goes.
December 20, 2007, 02:00:38 am
Quantum TD
IP won't budge
December 20, 2007, 02:00:38 am »
Any news on the little IP that couldn't?
December 25, 2007, 10:54:39 am
Powjetta
San Diego CA
IP won't budge
December 25, 2007, 10:54:39 am »
I had to loosen my fuel lines a little to help with the adjustment.
'86 jetta 2 dr Turbo diesel K24 - sold
'94 GMC 6.56TD - sold
January 02, 2008, 05:15:58 pm
rabbitman
IP won't budge
January 02, 2008, 05:15:58 pm »
It could be that the IP it a tooth off on the belt, yeah I know, you didn't wanna here that :wink:
January 03, 2008, 07:27:11 am
IP won't budge
January 03, 2008, 07:27:11 am »
http://vwdiesel.net/phpBB/viewtopic.php?t=10569
Hopefully this helps
General Information
Troubleshooting
IP won't budge
