one hole vs two hole head gasket ?
by
giulianot
on 06 Dec, 2007 07:47
How much of a drop in compression would i see if i put a two hole head gastket in the place of a one hole headgasket? The difference is only .04 mm but what does that equate to in drop in compression? Is the difference so little that i wont even notice it on cold starts? anyone done this before?
#1
by
on 06 Dec, 2007 08:08
I really doubt you'd notice anything at all.
#2
by
on 06 Dec, 2007 09:26
if it got really cold you might notice it a little. otherwise you won't notice it at all above 0 deg C unless you have bad compression.
#3
by
shegel
on 06 Dec, 2007 09:44
if you had a td then could you run the thicker gasket and then up the boost/fuel
#4
by
on 06 Dec, 2007 10:06
but this won't really help those subzero cold starts... great for a summer hot rod though :twisted:
#5
by
shegel
on 06 Dec, 2007 10:58
it doesnt get that cold here though....is it comparable to the compression loss that results from using the 1.9 head on the 1.6 block
#6
by
giulianot
on 06 Dec, 2007 11:35
Up here in the great white north we see temps as low as -30 deg c , my application is on a 1.9 aaz the old gasket after 300 km use :roll: here are some pics of my burnt one hole headgasket. :x
#7
by
on 06 Dec, 2007 11:37
Are 1 holes just not available? You could always get the block skimmed a little for the 2 hole.
#8
by
giulianot
on 06 Dec, 2007 12:05
Auto-camping only has 2 hole victor rienz in stock and 1 hole elna head gasket. I've never heard of elna, are they a reputable manufacturer? I wanted to use a 2 hole gasket thinking that it might eliminate haed gasket failure under high boost. Is thinking correct?
#9
by
on 06 Dec, 2007 14:11
#10
by
on 06 Dec, 2007 21:29
it might not eliminate hg failures, but it will surely reduce the possibility of them occuring.
the only reason these motors have such high compression is for cold starts. you could probably get away with 300 psi compression or maybe even a bit lower if the car was started at full operating temperature.
it has been stated before in some threads that using a thicker hg to decrease compression isn't a wise idea as it changes something to do with injector spray pattern in the piston reliefs or something like that... i have a huge headache otherwise i'd remember.
#11
by
fastvicar
on 07 Dec, 2007 08:35
What about the 3-notch one?
