KKK K24 Boost Controller?
Topic: KKK K24 Boost Controller? (Read 2697 times)
November 11, 2007, 04:23:21 pm
starrd
November 11, 2007, 04:23:21 pm »
Looking for some experience here. I am in the process of rebuilding my 1.9 TD in my passat and will be going to a rebuilt K24 turbo and Giles pump. I am wondering if someone can explain how they are installing a boost controller and what pressure they are setting it to. Also what are you using for a boost controller. I have read how some are doing it by teeing into the line on the turbo, and some are intalling a plug but I want to be sure. A diagram/picture would be helpful. Thanks
Black 1996 Passat TDI Malone tune, K03/04 Hybrid, Keyless, VR6 Clutch & PP357's
White 1993 Passat TD - GTD nozzles, Keyless - Giles pump, K14, Intercooler, 228mm VR6 clutch & PP, CTN Trans etc
Red 1990 Corrado - custom chip by
November 11, 2007, 05:13:21 pm
stewardc
November 11, 2007, 05:13:21 pm »
I'm gonna be using a 2-stage unit
http://www.turboxs.com/shop_prod.php?what_category=1
on basically the same unit. I'll be running 10-12psi on stage one and 22-25 on stage two.
It tees into the line from the turbo to the wastegate. Instructions are included with the unit.
November 11, 2007, 06:46:36 pm
blkboostedtruck
November 11, 2007, 06:46:36 pm »
hey stewardc,
I never knew they had those? thats way kewl! I was thinking of having the switch like thats on my show caddy that has a hurst "T" shifter N.O.S. button on the side and i just hold the button in for more boost for my turbo diesel caddy!
but i don't think i'll ever find one of those shifters again?
thanks Duane
injector rebuilds call 414-840-1395 for faster service not on line much!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
3 jettas '82' '04 '14TDI
November 12, 2007, 02:27:28 am
stewardc
November 12, 2007, 02:27:28 am »
Hey....Go to the Hurst site and order just a Competition Plus handle (from the parts bin) and weld it to the Rabbit bottom. We used to do it all the time at the speed shop.
November 12, 2007, 06:02:02 am
blkboostedtruck
November 12, 2007, 06:02:02 am »
I'll take a couple of pics. of my truck close up of some unique features it has for ya! the shifter i got for it is is way kewl and you would like the back window also! it's the only one i ever found!
Duane
'66 variant 1500S
