alright just wonderin if the t3 will just bolt straight on to the standard manifold cheers
No, not without and adaptor to the TDi manifolds... as they have a triangular flange and/or are integrated (the turbos that is) directly into the manifold.
It would fit a 1.9 AAZ TD or a older 1.6 TD exhaust manifold.
joe
well will the either of TD manifolds fit the TDi lol if not where bouts can i find an adaptor plate cheers joe
andy
any of the 8v manifolds will fit the TDI...they are standard across the board... IDI TD manifold, AAZ 1.9 manifold...gasser turbo manifold...even NA manifolds.
I don't believe anyone is marketing the "adaptor" plates...all the ones I've seen are custom made... its not too complicated to make if you have some time.
Even better if you have someone with a laser cutter for flanges and/or a CNC
Joe
so basically id be best gettin a manifold off a another mk3 diesel yeh cheers man
