Thanks for adding your insights, Chris.
When I took the car out I was concerned about overboosting it without any protection, so accelerated very smoothly, keeping a good eye on the boost gauge. I first got 5 psi, then 7, then 9 and finally 12 when I ran it out in 3rd after about 10 minutes of driving. I added 5-bucks worth of diesel since the fuel gauge barely rose off dead empty after engine start, then came home, working my way up on boost. I was very surprised that it wouldn't develop more boost than it did.
However, now that I think about it, there are a couple other observations I should mention, in case they may be affecting my results. First, I noticed that although the engine revved quite freely, it seemed to be a bit down on seat-of-the-pants power, so I stopped and hooked up the G-Tech. It recorded just 40 max hp. Clutch...? :?
Second, the engine now puts out a lot of black smoke once the boost gets above about 5 psi. It's not blue "oil smoke". It is the classic diesel looking black smoke...maybe very dark grey. Ideas?
Finally, I just now took this pic. It shows the disconnected hard line to the wastegate, the compressor scroll plug and the compressor wheel. (I disassembled everything to take the pic - I don't run it this way.) Notice that the blades are pretty chewed up. Bad as it looks, I somehow doubt this is what's keeping me down at 12 psi. Any ideas?
Thanks! Stan
