Author Topic: Garret turbo can anyone identify?  (Read 4366 times)
September 08, 2007, 08:58:27 am
foxracer1
  • Authorized Vendor
  • 991
« on: September 08, 2007, 08:58:27 am »
.53 AR compressor
.64 AR turbine
numbers on compressor data plate:
352421126
757246-1
s/n108010031
The center sectin looks very much like a VNT. As does the control. It doesn't look like a wastegate. If you guys know what she is please let me know.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #1September 08, 2007, 09:22:47 am
foxracer1
  • Authorized Vendor
  • 991
« Reply #1 on: September 08, 2007, 09:22:47 am »
My friend got it from Ebay he knew nothing about it. I'm sure it was to long ago to look up the ad. It looks very similar to my TDI VNT but very different at the same time.
91 S10 305 TPI T56
Reply #2September 08, 2007, 09:56:30 am
zaprzal
  • 160
    • turbodiesel.pl
« Reply #2 on: September 08, 2007, 09:56:30 am »
I think it's 35242112G not 352421126 and than google is your friend ;) some kind of gt22? jeep diesel turbo?
1.6td 170hp 290nm powered by Holset - sold
golf mk2 1.9tdi PD 193hp/400nm ;)
Reply #3September 08, 2007, 10:14:23 am
bigblockchev
  • 271
« Reply #3 on: September 08, 2007, 10:14:23 am »
Linkage looks like vane control to me. Cheers Dan
it's always something simple
one test is worth a thousand guesses
95 Chev Suburban 6.5 w performance mods
91 Mercedes 300D 603.960 6cyl 3L
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
5.5 years and counting on B100
Reply #4September 08, 2007, 10:44:19 am
foxracer1
  • Authorized Vendor
  • 991
« Reply #4 on: September 08, 2007, 10:44:19 am »
Nice well now i wonder what to do with it? Thanks for your help guys.
91 S10 305 TPI T56
Reply #5September 08, 2007, 10:57:28 am
zaprzal
  • 160
    • turbodiesel.pl
« Reply #5 on: September 08, 2007, 10:57:28 am »
Quote from: "foxracer1"
put it on 1.6td with some 11mm pump  8)
Reply #6September 08, 2007, 11:00:20 am
Zulfiqar
  • 254
« Reply #6 on: September 08, 2007, 11:00:20 am »
that almost looks like a turbo from a 2.2 litre mercedes CDI.
Diesel IS the future
Reply #7September 08, 2007, 01:15:13 pm
bigblockchev
  • 271
turbo stuff
« Reply #7 on: September 08, 2007, 01:15:13 pm »
With very little info available you will have to make some educated guesses as to how to apply it. If the turbine and compressor wheels are similar in diameter to other VW adaptable turbos it will probably work so some extent. the AR ratios sound similar to ones I have seen quoted on these forums. The biggest problem that you will face is that you will have to make up manifolds and adaptors to fit the unit to your head. The question arises will it perform better or worse than other more commonly available turbos, after going to the trouble and expense of getting manifolds made up. If you could just bolt it in and try it the answer would be clear , but there are a lot of unanswered questions. good luck Dan
2000 Jetta TDI
Reply #8September 08, 2007, 02:39:55 pm
Benjamin
  • 485
« Reply #8 on: September 08, 2007, 02:39:55 pm »
i think this is a gt22v/gt23v/gt25v
go for a big pump and you get all the power you want with this turbo
Greetz, Benjamin
SMOG alert, engine running again!
Must make +250hp
Reply #9September 09, 2007, 09:27:45 am
foxracer1
  • Authorized Vendor
  • 991
« Reply #9 on: September 09, 2007, 09:27:45 am »
What would it be worth to you?
91 S10 305 TPI T56
Reply #10September 09, 2007, 12:01:49 pm
Tintin
  • 1279
« Reply #10 on: September 09, 2007, 12:01:49 pm »
VNT22 from jeep.
Reply #11September 09, 2007, 01:45:08 pm
OM617
« Reply #11 on: September 09, 2007, 01:45:08 pm »
GT2256V from a Jeep Liberty CRD.
