Garret turbo can anyone identify?
Topic: Garret turbo can anyone identify? (Read 4481 times)
September 08, 2007, 08:58:27 am
foxracer1
Authorized Vendor
September 08, 2007, 08:58:27 am »
.53 AR compressor
.64 AR turbine
numbers on compressor data plate:
352421126
757246-1
s/n108010031
The center sectin looks very much like a VNT. As does the control. It doesn't look like a wastegate. If you guys know what she is please let me know.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
September 08, 2007, 09:22:47 am
foxracer1
Authorized Vendor
September 08, 2007, 09:22:47 am »
My friend got it from Ebay he knew nothing about it. I'm sure it was to long ago to look up the ad. It looks very similar to my TDI VNT but very different at the same time.
91 S10 305 TPI T56
September 08, 2007, 09:56:30 am
zaprzal
September 08, 2007, 09:56:30 am »
I think it's 35242112
G
not 35242112
6
and than google is your friend
some kind of gt22? jeep diesel turbo?
1.6td 170hp 290nm powered by Holset - sold
golf mk2 1.9tdi PD 193hp/400nm
September 08, 2007, 10:14:23 am
bigblockchev
September 08, 2007, 10:14:23 am »
Linkage looks like vane control to me. Cheers Dan
it's always something simple
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan MDJF 15Kw genset
September 08, 2007, 10:44:19 am
foxracer1
Authorized Vendor
September 08, 2007, 10:44:19 am »
Nice well now i wonder what to do with it? Thanks for your help guys.
91 S10 305 TPI T56
September 08, 2007, 10:57:28 am
zaprzal
September 08, 2007, 10:57:28 am »
Quote from: "foxracer1"
put it on 1.6td with some 11mm pump
September 08, 2007, 11:00:20 am
Zulfiqar
September 08, 2007, 11:00:20 am »
that almost looks like a turbo from a 2.2 litre mercedes CDI.
Diesel IS the future
September 08, 2007, 01:15:13 pm
bigblockchev
turbo stuff
September 08, 2007, 01:15:13 pm »
With very little info available you will have to make some educated guesses as to how to apply it. If the turbine and compressor wheels are similar in diameter to other VW adaptable turbos it will probably work so some extent. the AR ratios sound similar to ones I have seen quoted on these forums. The biggest problem that you will face is that you will have to make up manifolds and adaptors to fit the unit to your head. The question arises will it perform better or worse than other more commonly available turbos, after going to the trouble and expense of getting manifolds made up. If you could just bolt it in and try it the answer would be clear , but there are a lot of unanswered questions. good luck Dan
2000 Jetta TDI
September 08, 2007, 02:39:55 pm
Benjamin
September 08, 2007, 02:39:55 pm »
i think this is a gt22v/gt23v/gt25v
go for a big pump and you get all the power you want with this turbo
Greetz, Benjamin
Must make +250hp
September 09, 2007, 09:27:45 am
foxracer1
Authorized Vendor
September 09, 2007, 09:27:45 am »
What would it be worth to you?
91 S10 305 TPI T56
September 09, 2007, 12:01:49 pm
Tintin
September 09, 2007, 12:01:49 pm »
VNT22 from jeep.
Reply #11
September 09, 2007, 01:45:08 pm
OM617
Reply #11 on:
September 09, 2007, 01:45:08 pm »
GT2256V from a Jeep Liberty CRD.
