Moving along... Last couple days work.
New pistons installed. New rod bolts etc.
Head is on and torqued. One notch MLS head gasket...
Intake installed, upper elbow in an NOS 068 from the hoard, rubber hose too.
Exhaust manifold on and torqued.
Didn't fully torque that turbo down, yet. Also need to dig out the correct support bracket for the 171 down pipe.
Moved on to fitting some 1.6TD oil return lines to the NOS oil pan. There were 2 pans, different angle on the fitting on pan and each used a different oil return tube.
Uncrimped the SS braided hose from the required return line to fit this pan. Taller block so it needs lengthening. New hose should be here tomorrow. 3 Otiker clamps at each end will be adequate.
Had to align the tubes.
Decided to use a -4 AN line for the oil feed to turbo. Line and all Stainless steel fittings arrived today. Still waiting for the SS banjo to -4 for top of oil filter housing, Stainless bajjo bolt too. Fitting for top of turbo to AN is steel. SS for that was elusive in my search. Well, did find one in Taiwan for a few bux but wasn't going to pay $20 shipping plus fees.
