Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: GEE-BEE on July 15, 2014, 07:15:08 am
There stock in Europe
http://www.online-teile.com/audi/product_info.php?info=p333851006_028903141ap-halter.html&XTCsid=9e43721193ef35b707967e7e14c2844a
water pump are stock also
65.00
I ordered one and will advise fitment
I have several pics if there is anybody that will post for others
[email protected]
What is the point of it exactly? I have never heard of it before.
How's that work? Push Hot water into the bottom of the radiator instead of pull cold out? Maybe made to back flush the heater core?
Explain this one for us as we really do want to know. Purpose is????
coolant flow is the same, the water pump just spins in the opposite direct.
removing p/s from a ahu build with a/c
This is the way to run a complete serp and no v-belt to waterpump
http://www.vwdiesel.net/forum/index.php?topic=9599.30
GB
Ahhh ha moment
I'll reiterate what I mentioned in the other thread. I would personally rather have the water pump on the single v-belt and all the other accessories separate rather than have the water pump with all the other accessories. The water pump is the only essential belt driven item. Making its operation rely on the proper function of the serp belt, tensioner, A/C compressor and Alt means that if any of those items fail, you are dead in the water.
With a 6pk belt, I will take my chances
Thanx Libby for your input....
Some people just have to be different....
I invented the first silicone/fiberglass aircraft valve cover gasket
The first were for just my aircraft, then the word got out....
Some models have 144 valve cover gaskets per aircrat ( B25 )and with these we have eliminated the leakage
Cheers to all here
GB
do you make Volkswagen gaskets?
Next will be exhaust gasket and the intake..
Intake silicone with fiberglass, no oil soak etc
The exhaust will be a very advanced material we use on aircraft exhaust, without the aircraft cost
Stay tuned, and dont touch that channel...
GB
How about an AHU valve cover gasket?? :D :D
It's molded
I always drill and tap thr head and install the G60 valve cover/g60 vlave cover gasket
It's molded
That won't work with the AHU though, it has a wavy front. The AAZ works with the G60 cover but not the AHU /1Z.
ahu
http://www.autohausaz.com/search/product.aspx?sid=slukq0blon0hwfndo4opot45&makeid=800026@VW&modelid=1360112@GOLF TDI&year=1997&cid=20@Engine Parts, Seals %26 Gaskets&gid=10710@Valve Cover Gasket
EXHAUST AHU
http://www.autohausaz.com/search/product.aspx?sid=slukq0blon0hwfndo4opot45&makeid=800026@VW&modelid=1369661@JETTA TDI&year=1997&cid=20@Engine Parts, Seals %26 Gaskets&gid=5400@Exhaust Manifold Gasket
INTAKE AHU
http://www.autohausaz.com/search/product.aspx?sid=slukq0blon0hwfndo4opot45&makeid=800026@VW&modelid=1369661@JETTA TDI&year=1997&cid=20@Engine Parts, Seals %26 Gaskets&gid=5424@Intake Manifold Gasket
aaz
http://www.autohausaz.com/search/product.aspx?sid=slukq0blon0hwfndo4opot45&makeid=800026@VW&modelid=1283958@JETTA TDI&year=1996&cid=20@Engine Parts, Seals %26 Gaskets&gid=10710@Valve Cover Gasket
INTAKE AAZ
http://www.autohausaz.com/search/product.aspx?sid=slukq0blon0hwfndo4opot45&makeid=800026@VW&modelid=1283958@JETTA TDI&year=1996&cid=20@Engine Parts, Seals %26 Gaskets&gid=5424@Intake Manifold Gasket
EXHAUST AAZ
http://www.autohausaz.com/search/product.aspx?sid=slukq0blon0hwfndo4opot45&makeid=800026@VW&modelid=1283958@JETTA TDI&year=1996&cid=20@Engine Parts, Seals %26 Gaskets&gid=5400@Exhaust Manifold Gasket
this is a complete assy
Housing is here today
cant install a larger than 90 amp alt
http://www.partsbase.org/vw/caddy-ca-eu-1997-caddy-pickup-12113-compact-bracket-coolant-pump/
http://www.partsbase.org/vw/caddy-ca-eu-1997-caddy-pickup-90330-alternator-and-single-parts/
I cant run a a/c compressor either
http://www.partsbase.org/vw/caddy-ca-eu-1997-caddy-pickup-26015-a-c-compressor-with-individual-parts/
