Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: GEE-BEE on June 10, 2014, 09:45:07 pm
Title: Darkdside Tubular Exhaust And GTB Turbo Downpipe MK1
Post by: GEE-BEE on June 10, 2014, 09:45:07 pm
Shipped both new items today to Techtonics tuning for mock up of the 2.5 downpipe for the MK1
This turbo has the exhaust on the opposite side Passenger ) so a new different downpipe must be made..
I ordered a 2.5 Complete exhaust with a Borla Muffler for the build from TT
Next: will be the custom snorkel doing a 180 degree bend back into the MK1 TD airbox, I will make a insert for the engine breather tube
I mfg ( copied ) the original MK1 snorkel years ago and they are  still selling
GB
Title: Re: Darkdside Tubular Exhaust And GTB Turbo Downpipe MK1
Post by: theman53 on June 11, 2014, 06:24:42 am
Do you make any block off plugs about 3/4" OD for areas like the engine breather tube. I want to try blocking off the hole in my aluminum pipe but haven't found anything that didn't take up a lot of volume inside the pipe or that had a decent enough head that I wasn't worried about it falling in and getting stuck in the turbine wheel.
Post by: vanbcguy on June 11, 2014, 06:41:36 am
GB
I'd be interested to know more about the insert for the breather tube.  I ended up using high temp epoxy to seal the heater in to my aluminum intake pipe - it works but it's not as pretty as I would like.
Title: blockoff
Post by: GEE-BEE on June 12, 2014, 07:01:33 am
use a plastic Dual hose barb joiner with a rubber nipple and clamp
Iam going to mock up what I need and make a mandrell to do the silicone layup
Here is the aircooled bus intake boot I make
http://www.thesamba.com/vw/classifieds/detail.php?id=1321070
I sell these lot hot cakes to Hobo's
Post by: theman53 on June 12, 2014, 04:07:41 pm
Where do you get the rubber nipple?
Post by: GEE-BEE on June 12, 2014, 06:37:17 pm
ace hardware etc
Home depot might have them also
also know as rubber cap's
what size ?
here is 5/8 and 3/4
http://www.ebay.com/itm/Fits-Camaro-5-8-3-4-Water-Pump-Heater-Core-Rubber-Hose-Caps-Blockoff-Plugs-nos-/271391720223?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f3035031f&vxp=mtr#ht_381wt_983
http://www.ebay.com/itm/19mm-3-4-Silicone-Blanking-Cap-Intake-Vacuum-Hose-End-Bung-Plug-Silicon-10pcs-/230905709359?pt=Motors_Car_Truck_Parts_Accessories&hash=item35c30d832f&vxp=mtr#ht_1784wt_1221
I make mine with reinforcement
http://www.ebay.com/itm/KTM-Husaberg-350-Silicone-Thermostat-Bypass-Hose-Kit-With-Clamps-Gloss-Blue-/360848588819?pt=Motorcycles_Parts_Accessories&hash=item5404408013&vxp=mtr#ht_1028wt_1221
Post by: theman53 on June 12, 2014, 08:02:57 pm
that is what I was looking for the 5/8 IIRC. thanks
Post by: RabbitJockey on June 16, 2014, 06:24:59 am
the rubber ones suck, they start to crack and leak with in a year or 2.  i used one on the heater core pipe of my rabbit when i switched to non over flow radiator.
Post by: GEE-BEE on November 25, 2014, 06:18:57 pm
Finally got the complete exhaust and downpipe from TT
Downpipe was a freebie
exhaust and s/s poilished tip was 465.00
all 2.5 s/s
GB
Post by: oldpoopie on December 14, 2014, 11:04:02 am
Any photos?
Post by: mystery3 on February 28, 2015, 11:25:55 pm
I bought some silicone caps/nipples from 034motorsport, they held up for a few years w/o the failures I had previously with rubber, epmd I think.
Post by: rallydiesel on August 26, 2015, 07:12:23 pm
Pics? What engine and what turbo?
