Author Topic: Darkdside Tubular Exhaust And GTB Turbo Downpipe MK1  (Read 14093 times)
June 10, 2014, 09:45:07 pm
GEE-BEE
  • 1604
« on: June 10, 2014, 09:45:07 pm »
Shipped both new items today to Techtonics tuning for mock up of the 2.5 downpipe for the MK1
This turbo has the exhaust on the opposite side Passenger ) so a new different downpipe must be made..
I ordered a 2.5 Complete exhaust with a Borla Muffler for the build from TT
Next: will be the custom snorkel doing a 180 degree bend back into the MK1 TD airbox, I will make a insert for the engine breather tube
I mfg ( copied ) the original MK1 snorkel years ago and they are  still selling
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1June 11, 2014, 06:24:42 am
Re: Darkdside Tubular Exhaust And GTB Turbo Downpipe MK1
« Reply #1 on: June 11, 2014, 06:24:42 am »
Do you make any block off plugs about 3/4" OD for areas like the engine breather tube. I want to try blocking off the hole in my aluminum pipe but haven't found anything that didn't take up a lot of volume inside the pipe or that had a decent enough head that I wasn't worried about it falling in and getting stuck in the turbine wheel.
Reply #2June 11, 2014, 06:41:36 am
« Reply #2 on: June 11, 2014, 06:41:36 am »
GB
I'd be interested to know more about the insert for the breather tube.  I ended up using high temp epoxy to seal the heater in to my aluminum intake pipe - it works but it's not as pretty as I would like.
Reply #3June 12, 2014, 07:01:33 am
GEE-BEE
  • 1604
blockoff
« Reply #3 on: June 12, 2014, 07:01:33 am »
use a plastic Dual hose barb joiner with a rubber nipple and clamp
Iam going to mock up what I need and make a mandrell to do the silicone layup
Here is the aircooled bus intake boot I make
http://www.thesamba.com/vw/classifieds/detail.php?id=1321070
I sell these lot hot cakes to Hobo's
Giles Pump OHC
MK1 JETTA DASH
Reply #4June 12, 2014, 04:07:41 pm
« Reply #4 on: June 12, 2014, 04:07:41 pm »
Where do you get the rubber nipple?
Reply #5June 12, 2014, 06:37:17 pm
GEE-BEE
  • 1604
Giles Pump OHC
MK1 JETTA DASH
Reply #6June 12, 2014, 08:02:57 pm
« Reply #6 on: June 12, 2014, 08:02:57 pm »
that is what I was looking for the 5/8 IIRC. thanks
Reply #7June 16, 2014, 06:24:59 am
  • 5104
« Reply #7 on: June 16, 2014, 06:24:59 am »
the rubber ones suck, they start to crack and leak with in a year or 2.  i used one on the heater core pipe of my rabbit when i switched to non over flow radiator.
Reply #8November 25, 2014, 06:18:57 pm
GEE-BEE
  • 1604
« Reply #8 on: November 25, 2014, 06:18:57 pm »
Finally got the complete exhaust and downpipe from TT
Downpipe was a freebie
exhaust and s/s poilished tip was 465.00
all 2.5 s/s
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #9December 14, 2014, 11:04:02 am
oldpoopie
  • 46
« Reply #9 on: December 14, 2014, 11:04:02 am »
Any photos?
1985 jetta TD. It was free, and it shows. Down and dirty engine refresh made it run fairly well.... No leaks, except water into the cabin!
2001 golf Tdi. Heavy built ALH, soon to have a PD Frankenstein motor.
Reply #10February 28, 2015, 11:25:55 pm
mystery3
  • 774
« Reply #10 on: February 28, 2015, 11:25:55 pm »
I bought some silicone caps/nipples from 034motorsport, they held up for a few years w/o the failures I had previously with rubber, epmd I think.
Reply #11August 26, 2015, 07:12:23 pm
rallydiesel
  • 1880
« Reply #11 on: August 26, 2015, 07:12:23 pm »
Pics? What engine and what turbo?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
