General Information => General => Topic started by: theman53 on January 29, 2014, 06:29:53 am
Title: Summit Clearance sale
Post by: theman53 on January 29, 2014, 06:29:53 am
I bought this battery master disconnect for the Jeep project. It is a great price. They are selling tons more of the clearance stuff and it all looked to be good pricing from what I saw. I didn't look at all 360 items though.
http://www.summitracing.com/parts/gfr-3103/overview/
This is the link to the sale they sent me.
http://webracetrack.com/track?type=click&enid=ZWFzPTEmbWFpbGluZ2lkPTU2NTExJm1lc3NhZ2VpZD00NDAwMiZkYXRhYmFzZWlkPTUxODE0JnNlcmlhbD0xNjc4MzkwMiZlbWFpbGlkPU9ISU9BQlNFUlZJQ0VASE9UTUFJTC5DT00mdXNlcmlkPUFBTDE0QUFBQTAxMERVU0FCQVpDQlpaJnRhcmdldGlkPSZmbD0mZXh0cmE9TXVsdGl2YXJpYXRlSWQ9JiYm&&&2003&&&http://www.summitracing.com/redirect/?email=1401171&EmailCID=AAL14AAAA010DUSABAZCBZZ
Title: Re: Summit Clearance sale
Post by: Syncroincity on January 29, 2014, 05:59:54 pm
Thanks!  :D
Post by: theman53 on January 29, 2014, 07:05:04 pm
Even a blind squirrel can find a nut sometimes. I try to post the stuff that will be helpful. I have been wanting that disconnect for a second battery in the jeep project. I want to run a winch someday and now it is cost effective to buy that dead man switch, so I did :D
Thanks BTW
Post by: TimpanogosSlim on January 30, 2014, 03:10:49 pm
Thanks BTW
Ah, yeah that is cost effective.
I just spent like $27 shipped for a 2nd hand Blue Sea 4-position switch (batt 1, batt 2, batt 1+2, none) for my cruiser.
Roughly following this plan: http://www.george4wd.taskled.com/auxbat.html
Shame there are no VW diesel engines in the USA that will power my land bruiser. I'm looking at an Isuzu 4BD1T swap some day. I hope.
Post by: 745 turbogreasel on January 31, 2014, 01:37:01 am
Yota diesel right here  http://sfbay.craigslist.org/sfc/pts/4309899593.html
But if a 6Bt fits a 55, it's gotta fit an 80
Post by: theman53 on January 31, 2014, 05:13:50 am
The Wiki that I just looked at had the highest power for one coming out of a V8 that was 228hp and 302ft/lbs...an ALH could be built to out do that easily.
Title: Re: Re: Re: Summit Clearance sale
Post by: TimpanogosSlim on January 31, 2014, 06:48:31 am
No thanks. They are great engines but parts availability in the USA is pretty much zero.
6bt in an 80 has been done.
. :Sent by pneumatic tubes
Post by: TimpanogosSlim on January 31, 2014, 08:27:20 am
I don't doubt that we could build an ALH that would have those specs measured on a crank dyno.
But i suspect that the torque curve would look a lot different from a 4BD1T with 30psi of boost.
(4BD1T being Isuzu's 3.9 MTDI from the 80's, originally specified with a paltry 7psi of boost that it never really achieved except at sea level. The head on those from the factory breathes as well as a ported 4BT head, so they say, and there are other nice features like all of the 'yota sensors thread right in, the cylinders are sleeved from the factory, etc)
Post by: theman53 on January 31, 2014, 01:41:04 pm
I was just letting you know that it was possible as you said nothing was available in the US. Those numbers should be easy to achieve at the wheels with an alh and the alh will weigh 1/2 as much as a 4b. It is all in what you want to do, but you just sounded uneducated in VW diesel power possibility with what you had posted.
Post by: TimpanogosSlim on January 31, 2014, 08:21:53 pm
sure but at what RPM would an ALh deliver 300ft/lb?
Post by: 8v-of-fury! on January 31, 2014, 08:51:38 pm
^^ 2500-4000??
Post by: 745 turbogreasel on January 31, 2014, 09:50:58 pm
Doh! out of stock on my 2 5/8 hitch ball for $4 :(  At least they let me keep  the free shipping even though it dropped me under a hundred bucks.
Post by: TimpanogosSlim on January 31, 2014, 10:04:05 pm
^^ 2500-4000??
What I'm implying is that one of the things that comes with the 2x as heavy 4BD is that the torque hump is a lot lower in the rpm scale.
Post by: theman53 on February 01, 2014, 05:51:00 am
It will be a different depending on what turbo, intake, exhaust, etc you use. Usually it won't vary too much from where the stock was if you don't change too much. I have seen figures online that state stock the alh has 149ft/lbs at 1900rpm and I have also seen numbers that say 177ft/lbs at 1,900-2,400 rpm. I don't know what a trustworthy number is as I haven't dynoed a stock alh. Malone tuning says stage 2 will yield around 228ft/lbs around 2,100 rpm. That is only a nozzle and tune upgrade...and stage 5 would get you into the 300ft/lbs range right at 2,500rpm. The cummins 4b that I can find has 105hp@2,300rpm and 265ft/lbs @1,600rpm. So for the 780 pound 4b that is roughly what you have vs the 360 pound alh. I would bet the alh would seem quicker with the stage 2 tune than the cummins would stock since it would be 1/2 the weight, more hp, and 37ft/lbs less torque.
My point was you said nothing was here and it is.
Post by: TimpanogosSlim on February 01, 2014, 07:44:22 am
ok but you're still comparing a bone stock version of a similar engine to an ALH that has had a lot of money poured into it. isuzu 4bd1t with nothing but a td04hl-19t and an intercooler bolted on and the max fuel screw adjusted is closer to 380 ft/lb at 2000rpm. 4bd and 4bt are different engines, and the 4bd is the better engine. There are just a lot less of them out there.
At any rate i don't have the fabrication skills to devise a way of attaching an ALH to the A442F bell housing. but adapters for the isuzu are available.
Post by: theman53 on February 01, 2014, 07:55:06 am
I bet the numbers would be even closer with a 12mm fuel pump on the alh.
Post by: TimpanogosSlim on February 03, 2014, 07:32:45 pm
Perhaps a better question would be, for how long can an ALH be expected to power a 5000 pound SUV at those power levels?
Post by: theman53 on February 03, 2014, 08:18:52 pm
Which power level?
The MKIV jetta isn't really light at 3,000 curb, mine continually has another 1,000 lbs or so and it has roughly 260,000 at stage 2.
The real question is how stupid are you with your right foot? These engines are pretty tough, but not idiot proof. Yes the suv weighs more, but so does the other engine. How much more torque do you need to propel the extra 400lbs of engine? Point is the alh even in stock form could move it down the road. If you want it to double as a drag suv then it might not be the best for longevity and daily driving mix.
Post by: TimpanogosSlim on February 03, 2014, 09:36:09 pm
Which power level?
it's a land cruiser. if i can't beat it like a rented mule and expect it to just keep running like nothing happened, what good is it?
Post by: theman53 on February 04, 2014, 05:14:30 am
I would worry more about the land cruiser if you are going off road than the VW engine. Mall crawling then maybe the engine would have more problems.
I am putting an AHU type engine in a Jeep wrangler and have no reservations. I wouldn't have any in a land cruiser with an ALH. I have the skills to put it together though.
