General Information => General => Topic started by: JBG3 on November 06, 2012, 03:03:16 pm
Title: soot stains on interior, common problem?
Post by: JBG3 on November 06, 2012, 03:03:16 pm
so I have a dark coating of diesel soot deposited on the back of my rear seats, most notably the arm rest which apparently never came down.
I thought it was mold, but it smells like diesel exhaust, and can be brushed/shampooed out fairly easy.
The weird thing is that I can only imagine it coming in from a 2.5 inch round hole designed for a VO system, but the whole trunk was fairly dirty with soot as well.  Is this a common problem?
Ive been through the trunk after patching that VO line hole, and it seems impossible that it came in through there, but thats the only place I can find that was open to the outside.  The whole rear deck is sooty as well.  Here are some pics-
here you can see the soot on the rear seat-
(http://i1217.photobucket.com/albums/dd387/tinworm2/86%20VW%20Jetta/012-2.jpg)
and once you put the armrest down, its pretty nasty.  Comes right off on your hands and clothes, as if you stood right in front of the tailpipe for extended periods
(http://i1217.photobucket.com/albums/dd387/tinworm2/86%20VW%20Jetta/013-1.jpg)
Title: Re: soot stains on interior, common problem?
Post by: R.O.R-2.0 on November 06, 2012, 03:48:42 pm
its soot.. my car has a black back seat, and recaro fronts.. lol.
my back seat used to be light gray, once upon a time..
Post by: TylerDurden on November 07, 2012, 08:02:11 am
Any breech of the back trunk area will let in exhaust, if a window is open creating a low pressure zone in the cabin. (More likely if the AC is busted, of course.)
My 89 has a rust hole - I keep the windows up and the fresh-air blower on.
Post by: bajacalal on November 07, 2012, 01:03:48 pm
Replace your trunk/hatch seal with new weatherstrip and patch that hole.
I've noticed something about these cars. The air flows "the wrong way" if the front windows are open. It flows from the back towards the front. I guess this is due to the Venturi or Bernoulli effect or maybe both. This seems to be more pronounced in the earlier Volkswagen Golf/Jetta than it is in other cars, which have better ventilation, and is the worst when only the front window is open, which draws in exhaust from the rear, if the exhaust can get into the car. Opening a rear window negates the effect.
Post by: 745 turbogreasel on November 07, 2012, 02:06:01 pm
I get soot stains off my clothing sometimes, but that's about it.
Post by: Dakotakid on November 07, 2012, 08:48:17 pm
Is this electrostatic in nature?
Quick:  someone drag around a chunk of log chain to ground the body and see if this helps! ::)
Post by: JBG3 on November 08, 2012, 01:17:55 pm
could you do the same just running a bare steel rim on pavement?   ;D
Post by: JBG3 on November 08, 2012, 01:20:50 pm
im definitely going this route, the seats are otherwise reasonably clean, but ive never encountered this level of exhaust grime they apparently filtered.  The rear deck also looks like a used air filter, with soot showing through in every vent position.  My big concern is the amount of soot this indicates alarms me when it comes to me breathing inside the car.
Im not using the original engine or exhaust though, and the current 85 motor hardly smokes at all, so im not sure what was going on previously the create such interior filth.  I can say the original motor was completely blown though
Post by: bajacalal on November 08, 2012, 01:53:03 pm
I bet if you were to somehow measure the amount of air that's entering your car in the rear, in cubic feet, you would come up with a pretty big number over 100 miles.
You say you have an aftermarket exhaust. Where does it terminate? If it's before the bumper, a lot of exhaust can be drawn in the cabin, even at highway speed.
Post by: JBG3 on November 09, 2012, 07:12:09 am
sorry, I was unclear, im not using an aftermarket exhaust, I have an 85 stock 1.6 engine, and an 85 stock exhaust I moved over from a donor car.  The original exhaust was a piece of rattling swiss cheese though, and im not familiar with how the original engine ran before the PO destroyed it with abuse.
I patched the VO line hole, and I definitely need to replace the trunk seal.  For the last 10k I wasn't worried about it, as I had no door seals installed and no interior, and drove with two windows open constantly, but now that I have sealed up the car really well and put in new seals, while at the same time buttoning up all other leaks and holes in the cabin, im getting a little concerned at having closed up the cabin well enough for excellent exhaust retention over the winter.
yeah, over 100 miles it has to be a lot, or at least more than id like for sure.
Post by: RabbitJockey on November 09, 2012, 04:40:28 pm
theres a guy down the street i pay to suck farts out of my car seats, next time i go i'll see if he does soot or if theres anything he recommends.
Post by: JBG3 on November 10, 2012, 04:32:08 am
Yeah, let me know what he says, talent like that is hard to come by.  However, there's a local topless bar where I could probably have the same services performed on my seats as well provided I have enough singles.
Post by: RabbitJockey on November 10, 2012, 03:28:22 pm
I tried that before, they did a half decent job of getting the spot out but they left a lot of cheap glitter behind
Post by: wdkingery on November 12, 2012, 10:00:35 am
lol the glitter.
well anyway, i'm glad this thread formed, because my exhaust is comprised of mostly large leaks in various places, and it's likely i'm breathing this stuff in! i didn't think about the low pressure/venturi effect!
so i've opened my summer a/c vent and just diffused it.
glad ya'll mentioned this; wifey says i smell like soot every time i get home..:( i quit smokin two years ago!
Post by: R.O.R-2.0 on November 14, 2012, 01:43:26 pm
lol the glitter.
diesel smoke is much more pleasant to smell, than cigs are...
my car has JUST a downpipe, i know where my soot comes from... lol.
kinda makes me want to remove my recaros, and dump them back in the gasser...
Post by: JBG3 on November 15, 2012, 07:23:33 am
Well, last night went down to an upholstery cleaning establishment known as "the Cadillac lounge".  Turned out to be a price gouge, the girls were perfectly willing to suck the soot out of the seats, but in the process, got them all wet with spit.  I then had to pay them again to go through and blow all the seats dry.  Thats fricking highway robbery, im not paying for what I consider to be the same service twice in a row.  Additionally, as you said, I did notice a residue of glitter and lip gloss.  Goddam hookers.
Ill just stick to renting a steam cleaner I think.  It may not be as enjoyable to watch, but I think it might do a better job at a lower price.
Post by: RabbitJockey on November 15, 2012, 08:50:53 am
steam cleaners can be just as fun
Post by: CrazyAndy on November 19, 2012, 05:04:53 pm
All I can do after you said that is cringe while mumbling 'ow ow ow ow ow'.   Steam like that burns!
But seriously, haven't noticed anything like this.  I got my car's rust holes sorted for state inspection, as well as replacing my rear hatch seal as a matter of procedure, so no soot here yet.  Also have vinyl seats, so might not be as immediately apparent.  Does give me reason to wipe down the seats and trunk are when I pull the car out of the barn to install the 1.9TD after I build it.
Ow . . . steam burns . . .
Post by: ORCoaster on November 19, 2012, 08:07:34 pm
I had the ultimate sooty back cover when I bought the car.  I found some of the draft spots and extended the tailpipe but every once in a while I get "that smell" sneaking in.  No not "That Smell" either.  The sooty diesel one.
