Engine Specific Info and Questions => IDI Engine => Topic started by: monomer on November 03, 2012, 01:20:48 pm
Title: Toilet Bowl manifold differences?
Post by: monomer on November 03, 2012, 01:20:48 pm
Having some issues here (as normal...)
Motor came out of a mk2 jetta. Manifolds looked the same, scrapped the other two I had laying about. Car's a mk1 rabbit.
Install the DP today. The clamps interfere with the shift lever (USRT kit) I can't for the life of me figure it out, besides the manifold being offset for a different chassis.
Unless I missed something, I'm about to track down a header and be done with it.
Title: Re: Toilet Bowl manifold differences?
Post by: monomer on November 03, 2012, 01:54:27 pm
Pic:
(http://i23.photobucket.com/albums/b383/Monomer001x/2012-11-03_16-07-00_590.jpg)
Post by: theman53 on November 03, 2012, 07:31:16 pm
MK1 and MK2 have different downpipes.
Post by: burn_your_money on November 03, 2012, 07:41:53 pm
MK1 and MK2 have difference manifolds, and that's what's getting you.
MK2 exits behind cylinder #3, mk1 exits between cylinders 2 and 3
Post by: fatmobile on November 03, 2012, 10:31:26 pm
 I don't have any experience with the MK1 TD exhaust manifold and didn't know it was any different than the MK2.
 I have seen the stock MK1 turbo outpipe, it sets the toilet farther to the right.
Post by: monomer on November 03, 2012, 10:41:16 pm
It's N/A.
I call it a downpipe...because it kinda is still. For future reference, It's drivers side of passengers side on a car, left and right just don't cut it (UK's excluded.)   :-X
This is what I get for having a bunch of random vw parts laying around, it's been four years since this car's been together.  :-[
I'm just going to slap a header on it and be done. With this setup I'd be looking at fabbing up a test pipe, as the autotech exhaust I have is cat back, and the cat is long gone. Besides, how many diesels have you heard with a downpipe and decent exhaust?
Post by: R.O.R-2.0 on November 04, 2012, 09:39:22 am
It's N/A.
the header is gonna hit the steering rack unless you buy an EXPENSIVE header..
Post by: theman53 on November 04, 2012, 09:52:43 am
are you sure your shift linkage is set correctly? I have a missing linkz kit and it doesn't come that close to the block...MK2 but still.
Post by: R.O.R-2.0 on November 04, 2012, 09:58:39 am
mk2 manifold in a mk1 is the problem...
im sure the shifter is correct.
Post by: monomer on November 04, 2012, 11:09:25 am
A raceland or obx header wont work?
It shifted...fine.
Post by: burn_your_money on November 04, 2012, 08:48:06 pm
One off a Scirocco or 8v GTI would probably suffice (header)
Post by: mystery3 on November 04, 2012, 09:57:39 pm
It shifted...fine.
I had a cheapo header that I picked up with some other parts and ran it for a while on a mkI with no problems. Car had a "short shifter" consisting of a chromed shift lever with extra holes I found at the junkyard. I think a raceland/obx/ebay header should work fine as long as it's made for mkI.
Post by: R.O.R-2.0 on November 05, 2012, 10:46:54 am
It shifted...fine.
i was speaking of the pace setter headers..
either way tho, if you dont brace the hell out of it, the diesel will just vibrate it to bits..
my header vibrated off the studs a few times on my diesel.. finally made a brace from the block to the collector..
stayed put after that.
Post by: hillfolk'r on November 05, 2012, 07:06:38 pm
It's N/A.
Ya can make em sound great,the na's that is..im runnin a 2.25 inch homemade exhaust from the dp back with just a 12 inch long summit glasspack.
total cost,90$...
next hat trick is to remove the stock dp and make it like 2.25 to match the system.
its probably wirth 2.63 hp at 4193 rpms,and as much as 2.81 hp at 5276 rpms by my calculations that my butt dyno has extracted....
Ah who am i kiddin? Any power increase definitely came from the dtm tip
(http://i1260.photobucket.com/albums/ii563/hillfolkvwdude/2012-08-19001423.jpg)
