For Sale/Looking For => Parts for Sale/Wanted => Topic started by: giulianot on May 16, 2012, 12:54:53 pm
Title: 1.9 AAZ race motor and trany152hp 255tq
Post by: giulianot on May 16, 2012, 12:54:53 pm
Up for sale is my beloved 1.9 AAZ TD setup complete READY FOR A MK1 chassis for $2200 to a good home complete***IF THERE IS A BUYER FOR THE LONG BLOCK ONLY THEN I WILL CONSIDER PARTING OUT***
Yes this motor makes 152hp and 255 tq
This motor has less than 5000km on it since full rebuild
For those who don't know i have $4500 invested in this motor, link to build thread
Looking to sell locally or pickup only! PO L7K0Y7
http://forums.vwvortex.com/showthread.php?3485312-1.9-aaz-into-a-mk1-cabrio (http://"http://forums.vwvortex.com/showthread.php?3485312-1.9-aaz-into-a-mk1-cabrio")
http://www.vwdiesel.net/forum/index.php?topic=10690.0 (http://"http://www.vwdiesel.net/forum/index.php?topic=10690.0")
I will try to list some of the mods
Turbo
K24/k26 hybrid  3000km on it
Downpipe
2.5" Passenger Performance SS for mk1
Pump
1.9 AAZ Giles superpump st4 set for 24 psi (stock AAZ pump fuels 44cc@wot this pump fuels 98cc@wot
Head
1.9 AZZ match port and polish new pre cups new valves
ARP head studs
custom Doctor Diesel high lift cam
Intake port an polished
Exhaust manifold port and polished with EGT bung
Block
.5mm over pistons
ARP main cap studs
TDI half moon machined crank and crank pulley
Clutch
lightened flywheel
Eurodrive st4 clutch and pressure plate
Trany
ACN code with the tallest .065 5th
slip kit installed
for those who need pics
(http://i124.photobucket.com/albums/p28/giulianot/head%20instal/100_2202.jpg)
(http://i124.photobucket.com/albums/p28/giulianot/head%20instal/100_2213.jpg)
(http://i124.photobucket.com/albums/p28/giulianot/100_0444.jpg)
(http://i124.photobucket.com/albums/p28/giulianot/100_0446.jpg)
(http://i124.photobucket.com/albums/p28/giulianot/cabbymotor029.jpg)
(http://i124.photobucket.com/albums/p28/giulianot/cabbydynomarch2010001-1.jpg)
Title: Re: 1.9 AAZ race motor and trany152hp 255tq
Post by: CrazyAndy on May 16, 2012, 09:40:08 pm
PM sent.  :o
Post by: libbydiesel on May 17, 2012, 07:27:30 am
If eliminating the oil to water exchanger, you should not run the copper hose like that.  That allows coolant to bypass the radiator under all conditions.  The right way to eliminate the oil to water exchanger is to plug both lines or to use a non-turbo (no exchanger) bypass hose and plug the bottom.
Post by: giulianot on May 17, 2012, 07:34:06 am
This is very true, that is an old pic I did indeed  block the two oil cooler coolant hoses so that coolant would only flow through rad
Post by: libbydiesel on May 17, 2012, 12:05:12 pm
Right on.  BTW that looks like a great price for what you're selling.  If I was in the market for an engine I would snatch that right up.
Post by: 79rabbit4dr on May 19, 2012, 12:05:56 am
How streetable is this set up?
Post by: R.O.R-2.0 on May 19, 2012, 03:51:15 am
very streetable, its a diesel!
you gotta have an engine like Andy2 before you cant street it anymore..
Post by: giulianot on May 19, 2012, 04:01:33 pm
This setup is very streetable. It was in my mk1 cabriolet and used as a daily driver for a summer. Members on this board (burn_your_money and Dr. Diesel) have been in my car with this motor in it.
here is a video of a 1/4 mile run
http://www.youtube.com/watch?v=dOXs7z8ktYE (http://www.youtube.com/watch?v=dOXs7z8ktYE)
and dyno run
http://www.youtube.com/watch?v=gKXXVIsEtWo (http://www.youtube.com/watch?v=gKXXVIsEtWo)
Post by: R.O.R-2.0 on May 20, 2012, 12:16:52 pm
hows the K24/26?
i know some people say they are too restrictive..
Post by: 79rabbit4dr on May 20, 2012, 07:01:19 pm
I'm seriously considering selling my 4Runner for this so I'm going to ask a lot of questions, sorry.
What needs to be done to connect speedo? Tach? Exhaust? IC? do you have it pulled already or is it still in the cabby?
I'm looking to put it in my '81 NA Caddy. How much shipped to 83440 ID?
Post by: burn_your_money on May 21, 2012, 05:50:08 pm
T'is true. It was a fast and noisy car (placement of air filter, nothing to do with the engine, don't put the air filter in the rain tray if you like quiet).
Good honest seller as well
If I liked turbos, and needed a motor, and had money, I'd buy it :P
Post by: giulianot on May 28, 2012, 06:38:04 pm
lots of interest, no takers yet
Post by: Dr. Diesel on June 06, 2012, 05:37:07 pm
The turbo is not a normal hybrid-- meaning not a K24 with a k26 compressor section installed. It is a K26 installed into a K24. They bored the hot side out to fit the K26 turbine wheel. Compared to a standard K26, the exhaust scroll is smaller. We all know a healthy K24 can make 35 psi on a 1.6 and a little over 30 on a 1.9, so that smaller scroll isn't presenting much of a problem. In fact, it spools up the bigger, higher flow turbine faster than in a standard K26 configuration. So if anything, it it less restrictive than a K24, while enjoying spoolup times very similar to a K24. As you can see by the dynograph, this is NOT a peaky engine. The best part is, 152/254 was done on a paltry 24 psi.
This is an easy 200hp/350ft.lb. engine with more boost.
Whoever ends up with it will be quite satisfied with its as-is performance, and range of further tuning.
Post by: giulianot on June 09, 2012, 06:35:29 pm
sold! :)
