General Information => Troubleshooting => Topic started by: shwak23 on May 03, 2011, 09:39:36 am
Lost 5th in my MKII. Is there anyway I can squeeze a MKI Diesel tranny [That I already own] into my MKII? For cheaper than it would cost to buy/fix my silly gasser tranny I have now?
what trans are you taking out? does it have 100mm axle flanges?
whats going back in there? if its a mk1 diesel trans, it DOES NOT HAVE 100mm axle flanges..
gotta make sure your axle flanges are 90mm to fit the mk1 trans, or swap your inner CV joints to 90mm units.
but if you already have 90mm axles, then it should fit fine.
Ok well lets say the axles are non issue does the tranny bolt in? Do the mounts all work? Or does it require more fabrication?
its an 020, yes it will bolt in place of another 020, but you may not be able to hook up the axles.. if you cant hook up your axles to it, i wouldnt even worry about if it fits or not..
but yes, it SHOULD fit. as long as the final drive housing is drilled to accept the mk2 style rear mount.. and of course, the axle flanges fitting the axles..
you may have to change the gear selector linkage on the trans to the mk2 piece. i guess they ARE different..
Would the final drive housing be drilled? I guess this is all speculation without the codes eh?
exactly why i asked in my first post what you were taking out, and wanting to put back in..
Well I'll run outside in a minute and check it out. It'd be so super awesome if I could pull this off.
long run eh!
http://www.brokevw.com/020mount.html
Here you go big boy. :)
Just look at the mk2 tranny and see how it mounts then look at the mk1 tranny and see if it has what needs to be drilled. You could modify it to fit if need be...
These are the only MK1 trannies that will bolt into a MK2:
7A
9A
4K
2H
All the other ones (FF, FO, FM, FK, FN, F---, etc) will not bolt into a MK2. They lack the bosses on the differential housing for the MK2/3 rear mount.
A quick way to tell if the trans will work, is to look and see if the driver's side flange has a GREEN metal cup behind it that holds the seal. If it does, you're good to go. If it doesn't, it won't fit without you modifying the rear trans mounting.
Damn that was a long run!! All the way to the next town over where I pulled a different tranny blah blah blah i'm h4rDc00rzz. ;D
7A03113 is the tranny code. :-[
Looks like i'm *** outta luck. Or sompin.
Edit: Lol that warning that comes up that says "a new reply has been posted you may want to review your response"... I ignored it... But apparently i shouldn't have.
Man.. I'm so pumped it'll work. I was going to be so mad if it was the FF's that would fit and the 7A's wouldn't. I just sold a perfect FF. I'm gonna swap this asap. ;D ;D ;D
swap cases!
swap cases!
eeewww that sounds hard. ;D
Ok so I have the 7A but my Golf is a 1990 Golf Gasser converted to a Diesel but with the Gasser tranny. ::) Thank you PO. ::) Are my flanges good to go or should/can I swap the two?
Edit: By this I mean is one 100mm and one 90mm and can they be swapped?
A lot of the late MK2 gassers had 100mm flanges. I think the following had 100mm flanges: AUG, ACL, ACD, AON.
A lot of those codes did not appear in NA, so, they might not apply. I know that ACL and AUG were available in the USA.
Just measure and check. You can either swap the inner CV joints (easy), or swap the flanges (a bit harder and requires you to make/purchase a special tool).
what trans did you take out of the car? cant make a final answer about flanges till we know what the car HAD in it..
9A, 2Y, ACD, AGB, ACL, AON, and AUG got 100mm flanges..
if your car still had the stock trans, it SHOULD have an AUG and it had 100mm flanges.
FWIW, being that your car is a gasser, and a 1990, im going to say that it DOES have 100mm axle flanges..
Flanges are the easy part, they can be swapped between the two tran's pretty easy. The 7a may not have the mount locations on the final drive housing for the rear trans mount- seems to be some conflicting info on that. BrokeVW's chart basically says 7a won't have the mount locations but a few folks say it may. On the 90-100mm flanges you can swap the flanges pretty easy between them with a homemade preload compressor(flat bar with hole and bolt)!
Which would be easier? Swapping the CV shafts? Or the inner flanges?
do you have a set of 90mm inner CV joints? thats the easiest swap..
Yep. Just a circlip and no special tools and the BS of tensioning the flanges. If you pull them, you'll need to replace the seals back there. But then again, it's a good idea to replace them.
Before 1987 all transmissions had 90mm
1987 and up, they had 100mm
no.
under 100hp = 90mm
over 100hp = 100mm
late eco diesel jettas have 90mm axles.. and they didnt even come out till after 87..
and my 85 GTI, 100mm axles stock..
I checked it out and it'll fit but when I undid the pass. side CV shaft a bunch of gear oil leaked out. ::) So looks like i'll be taking those flanges off anyway. >:( Oh well at least it fits.
why do you have to pop the flanges off to replace that plug? its right under the axle, in the center of the drive flange.. super easy to replace. no need to take the flange off.. unless you are going that rout to make things fit.
what year is the 7A?
*edit, i just checked, its a 1983 trans, it should have the conical washers and springs and stuff.. if you do a flange swap, the AUG flanges should fit right on there*
Oh I didnt' know you could just replace the plug. I thought there was more to the process. I'd much rather just replace the plug. Slap on the 90mm axles I have and call it good. I really don't want to mess with this to much. I can't really take my car off the road for more than two days. In a month or so I'm going to be installing the turbo onto this car anyway so I may as well just save the 100mm flanges and if and when I put on the turbo I'll swap those onto the 7A if i'm feeling up to it.
90mm flanges and axles are just fine unless you are going to be building 250hp or so ;)
and at that point, you would want a different style transmixer.. the trans is the weak point, not the acles or CV joints (unless they are worn clear out)
Pretty sure the 1.6's came with 250hp stock. ::) Duhh.... #winning...
Anyway I got the tranny out of the other car today. Tomorrow I'll start cleaning it and touching it and examining it until it grows up to be a serial killer and getting it ready to be put into the MKII. Blah. One project after another.
welcome to the wonderful world of VW ownership..
More like the story of my life. I only ever had one car that's younger than me and thats my 1990. Lol
