General Information => Troubleshooting => Topic started by: Smokey Eddy on July 04, 2010, 02:21:24 am
Title: Question regarding new intermediate shaft bearings
Post by: Smokey Eddy on July 04, 2010, 02:21:24 am
When you pressed in your new intermediate shaft bearings, did the shaft want to bind in the bearing? did it take some encouragement to spin freely?
how freely did it spin with new bearings?
Title: Re: Question regarding new intermediate shaft bearings
Post by: rs899 on July 04, 2010, 03:29:10 am
IIRC it was a little stiff but I could still turn the naked shaft by hand.  I only did the outer one, though.  With the pulley on I could not tell the difference.
Post by: theman53 on July 04, 2010, 04:40:18 am
I can't turn mine without the pulley on. I maybe could spin it a little in each direction. Put the pulley on and I can spin it. It is still stiff, but I can spin it no problem. I was worried too and asked the same question. You will be fine, that tight tolerance will keep your oil pressure up...unlike last time  ;)
Post by: cyrus #1 on July 04, 2010, 12:19:22 pm
What type of bearings did you get?  Are they the pre-fit ones?  Or the ones that need to be reamed for proper fit?  Did you install them yourself?
Post by: Smokey Eddy on July 04, 2010, 12:31:23 pm
Cyrus, they are the ones from mopac that come in the blue box. they are already machined i believe and i pressed them in with a homemade tool. the all thread with a 1 inch black pipe cap ground down to fit.
the issue is the the back race is badly damaged which i think is causing some slight issues.
Post by: Smokey Eddy on July 05, 2010, 12:57:36 am
with the pulley on the shaft i can only just turn it with one hand.
Post by: rs899 on July 05, 2010, 02:16:40 am
You might want to take a good look at the edge that contacted the tool and see if it's buggered.  If so, take a small file and chamfer it lightly
Post by: Smokey Eddy on July 05, 2010, 10:26:42 am
I did so with 600 grit wet dry.
My drill spins it effortlessly so once it's got oil to suck up i'll prime it with the drill.
Post by: Smokey Eddy on August 02, 2010, 10:27:22 pm
Just an update. After about 600km the shaft spins freely by hand and there is lots of pressure.
