Engine Specific Info and Questions => IDI Engine => Topic started by: Doakster on September 07, 2009, 05:50:03 pm
Anyone run a Peloquin or Quaife limited slip? My trans is out right now and I'm considering buying one. Anyone now the pros and cons to each?
I had a hypo gasser Caddy once with a quaiffe and it rocked.
pros and cons of limited slip? they suck in the rain if you are throwing power to them. basically its instant posi-traction, just add power. josh (Powered by Spearco) just bought a nice LSD for his drag car. might ask him about it and where he got it and paid for it.
Quaife and Peloquin are essentially the same type of differential, the driving experience with both will be identical. Peloquin's are generally a bit cheaper and most of what I have read says they are also more durable. But Quaife was the first one in the game with FWD VW's.
Thanks, that's what i needed to hear. I'll be getting a price from a local VW performance shop to do a rebuild with a Peloquin.
There's a guy in Auburn that builds VW transmissions he's been doing it for many years now and he is very reasonable. pm me if you want his number. I wouldn't be surprised if you he could hook you up with a good used LSD.
Tried to send you a PM
Don't forget wavetrac:
http://www.wavetrac.net/technical.htm
Autotech likes them.
www.brokevw.com is also a well noted tranny rebuilder.
I notice on his site he says he's booked into 2010.
I got a price of around 1300-1400 for a complete rebuild with a peloquin for my AVX trans. Think i might go ahead and do it.
ouch. theres guys rebuilding transmissions for 500 bucks in oregon. theres a few good shops in portland that rebuild transmissions cheap. but you are somewhere else. and that seems like an aweful lot just for a rebuild and LSD install.
The peloquin is costing me 875 alone, and around an other 400-500 for the rebuild. The diff is what's costing so much.
ok, that makes more sense. but uh, if i ever do something, im just gonna do an 80% mini slip in my transmission. i think its less than a hundred bucks for one if you can find it?
I think Brian is to the trans what Giles is to the IP - a master craftsman. He has been quick in the business I have had with him. I'd get on his list if you want a quality job.
I'm going with wavetrac - You can fin them for under $700 all day long and the company support is fantastic, from what I've seen.
I actually got another guy to do it, I'm saving a little money, bought a peloquin today which is on sale with APtuning and a seal kit with GAP. I'm dropping the trans off to the guy tomorrow, he'll be pulling it apart to check for anything else i need. He said labor will be about 200 for tear down and assembly. Which will put me in the 1100-1200 range.
Where are you finding the Wavetracks for under $700?
Little update. Trans got put back together with a peloquin and 3.94 final drive.
Here was the damage.
Peloquin: On sale at APTuning, including ARP hardware and bearing: $815 shipped
Labor for rebuild: $200
3.94 Final Drive: $150
Gasket/Seal Kit: $60
Pinion Bearings and Misc: $50
Total: $1275
I should be able to sell my 4.25 R&P for hopefully around $300, so that will put me at $975, not bad at all for a rebuilt trans with a LSD.
Hopefully i'll have it back in the car and up and running tomorrow if all goes well.
