Model Specific Questions and Info
» MK2 Golf/Jetta and Audi 5k
View full version:
4
Manual Adjust Clutch Cable Substitution
Alternator problems
MK2 1.6 NA Diesel Coolant Replacement
Transmission Whirring Noise??
Good buy? 1991 Jetta 1.6 td w/ Hood Stack
Belt Tension Gauge Instructions
Lithium Jump Starter
"Best" Engine Mount Solution
Mk2 clutch not engaging.. Brand new
Steering Wheel locking up. HELP!
Bubbles in Fuel Line, Comments Requested
Swap Golf 2 TDI 110
86 Golf with AC - how to swap the tranny?
Just purchased an 89 Jetta N/A have a few questions
How to Reshape/Reuse Injector Heat Shield??
Leaking Proportioning valves on master cylinder
Vacuum Pump R&R
Blowby Pressure???
New axles
Installing tie-rods after manual steering rack replacement
MK2 Jetta EcoDiesel
Orifice - Altitude Compensation System WANTED
Beck Arnley wheel cylinders?
Substitute Master Cylinder and Reservoir for MK2 Jetta??
Compression Test AND/OR Leakdown Test???
New 1991 Ecodiesel owner in need of some cooling system help.
Power Steering Flush and Fill
Outer Intermediate Shaft Bearing Replacement Engine In Vehicle
Glow plug relay information 1986 Golf
1.6 Non Turbo to Turbo swap
Need help figuring out A/C and Alt bracket
86 Jetta Engine Mount Question
New to Me 86 Jetta 1.6TD White Smoke
VE Pump Rebuild Service
My 1991 Golf GTD PICS PRE RESTORATION!!
Replacing Oil Pan
AHU/AAZ 81mm headGaskets?
electrical installation mk2 golf gtd
91 Eco diesel Jetta starting problems
New to me 1986 Jetta deluxe diesel
Beaten Jetta after Mini Stock race needs help...
020 transmission leaking after 5 years
Oil pump..
91 Eco diesel Jetta AC question
Headlight Replacement For MK2 Jetta
Thinking of a new starter
Will a jk code 1.6NA fit into a 1988 golf 5 speed?
Strut oddness perhaps?
Perkins turbo
