Author Topic: Leaking Proportioning valves on master cylinder  (Read 6372 times)
November 04, 2016, 05:30:24 am
srgtlord
  • 797
« on: November 04, 2016, 05:30:24 am »
One of my proportioning valves on my master  cylinder is leaking from the rubber o-ring. These little valves seem to be NLA. I did however find a source that sells them for the cabriolet and scrirocco but visibly appear different and cost $140... a peice. Is there a rebuild kit available for these little valves? Would the cabriolet proportioning valve work?
Reply #1November 18, 2016, 09:16:48 am
thomas m
  • 144
Re: Leaking Proportioning valves on master cylinder
« Reply #1 on: November 18, 2016, 09:16:48 am »
Why not just get a new master???? Not to suggest that you haven't thought about that, but I am curious.
Is a replacement not available for your model????
Thomas, Original owner since new:
1991 MK2 Jetta Non-turbo 1.6 diesel, Engine Code ME, 5 speed 020 AWY 04120 transmission, Hydraulic Lifters,
320,000 miles
LOOKING FOR REBUILD OPTIONS IN PORTLAND, OR OR ON THE WEST COAST
Reply #2November 22, 2016, 04:21:18 am
srgtlord
  • 797
« Reply #2 on: November 22, 2016, 04:21:18 am »
It's not the master cylinder that's leaking g, it's the canister looking proportioning valve that screws into the master cylinder that I can't find anywhere.
Reply #3November 23, 2016, 01:31:00 pm
« Reply #3 on: November 23, 2016, 01:31:00 pm »
Yeah there's a few models out there with a proportioning valve mounted at the MC. Most non ABS cars have the proportioning valve mounted under the car on the rear axle.
Cross compatibility between braking parts is always tricky, especially with things like that. Good chance a cabriolet part would work but it may change the brake bias. That's definitely an engineered part chosen for a specific reason.
What year/model do you have exactly? You might be able to retrofit a complete "common" setup.
Reply #4November 24, 2016, 04:04:00 pm
air-cooled or diesel
« Reply #4 on: November 24, 2016, 04:04:00 pm »
did you try autohausaz? or partsplace, then again certain parts and more and more parts continually become unavailable. ?can also look for used ones; google 'used vw diesel parts' or in this case just 'used vw parts' may do,,gl.
Reply #5November 25, 2016, 05:43:56 am
« Reply #5 on: November 25, 2016, 05:43:56 am »
so i do believe theyre 2 piece proportioning valves, the bottom has 2 slots for an open-end. so take them out; put bottom end in a vice, the top should take a wrench, see if its loose; if so thats your problem; you can now either tighten up ,,-or take apart and clean up, a new o-ring in there, and tighten; i dont think you can find a torque for this, although some where there may be one, tighten so it wont leak, i tighten some more(a little), i has to not leak for some while,,.
Reply #6November 27, 2016, 02:52:31 pm
srgtlord
  • 797
« Reply #6 on: November 27, 2016, 02:52:31 pm »
Well I ordered some brake fluid compatible o rings for about  $15. I'll report back when I install one
Reply #7November 27, 2016, 03:05:50 pm
« Reply #7 on: November 27, 2016, 03:05:50 pm »
yea big difference between that and $140 per. hopefully it will do it.
Reply #8December 19, 2016, 07:51:40 am
srgtlord
  • 797
« Reply #8 on: December 19, 2016, 07:51:40 am »
Welp I ordered the wrong size o-ring...... I think I'm going to just break down and purchase the newer style proportioning valve and just set the height of the arm at a fixed position....
Reply #9December 28, 2016, 07:54:14 am
srgtlord
  • 797
« Reply #9 on: December 28, 2016, 07:54:14 am »
Well due to money constraints I begrudgingly  grabbed a proportioning valve off of my green vw golf that currently isn't registered. Problem solved.
