View full version: MK1 Golf/Jetta and B1 Dasher
« 1 2
  1. Caddy interior
  2. 1981 1.6 Diesel doesn't always start...
  3. Shop thinks my stuts are too long, inner cv's tear when the front is jacked up.
  4. 1.6L diesel fuel cell
  5. Any one looking for close out parts on 81 Rabbit or like machine?
  6. 4 spd to 5 spd swap
  7. 1981 Volkswagen Caddy Aux Fan controlled by climate fan
  8. 1.6l injection pump will not rotate
  9. Should have known
  10. bushings
  11. Mk1 OEM turbo diesel production numbers??
  12. Flattening a bowed tailgate
  13. '84 Jetta exhaust optiona
  14. In-depth video on how to remove a diesel engine from a MK1 but applies to gasser
  15. Westy fuel neck decal
  16. How many ?
  17. I Can't Fill My Tank - '79 Rabbit
  18. Can You Help Identify These Pieces?
  19. So the FNG Could Use a Little Help
  20. Greater Steering Resistance?
  21. HELP 1.6 Caddy wont start
  22. On a scale of 1-10, how screwed am I
  23. HELP me start my 81 caddy
  24. Satin Hi, I'm the New Guy
  25. 1.6 NA archaeology. Help me dig
  26. 10 Year Caddy Front end rebuild
  27. Whats Required 1985 Quantum Instrument Cluster in a Caddy?
  28. one key?
  29. 1.6 na Jetta crankcase hose headache
  30. dieselcraft oil centrifuge
  31. connect aftermarket alarm to aftermarket central lock
  32. 1981 Caddy
  33. MK1 Help!!!
  34. 83 caddy rocker chrome trim direction
  35. Caddy Seats seat warmers
  36. Best place to get a new windshield?
  37. Rabbit rear sunroof drains
  38. 020 Transaxle clutch chatter
  39. Rear spring bushings to caddy
  40. 1.6td Clutch
  41. 81 Rabbit 5 Speed Shifter Issue
  42. dual Pillar Pod for MK1 Caddy
  43. VW MK1 RABBIT TRUCK FUEL TANK ( ALLOY 18 GAL )
  44. BEDRUG FOR CADDY
  45. Caddy/Rabbit front sway bar..
  46. Battery Relocation MK1 Caddy Under The Bed ( Optima )
  47. Intercooler from mk5 vw TDI in my MK1?
  48. Sealing PS steering U-Joint shaft
  49. Another Build 1981 Caddy
