Author Topic: IT WON'T SHUT OFF!!!!!!!!!  (Read 3412 times)
February 08, 2005, 07:06:04 pm
SMOKEYDUB
  • 630
« on: February 08, 2005, 07:06:04 pm »
A couple days ago I took my beautiful BROWN 86 td jetta to the car wash you know wash it and all that crap and then i pop the hood and power wash it down quickly and after that it wouldnt shut off. So for a couple days i have had to stall it to stop the engine. What the crap! I checked the wire that goes to the fuel cutoff cylonoied (sp) and it looked perfect. So I hoping i will find out some info from you guys.
Thanks
Jeff
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #1February 08, 2005, 07:38:31 pm
Cheesetoast
  • 285
« Reply #1 on: February 08, 2005, 07:38:31 pm »
do  not power wash the engine on the td's.  If the injector pump is hot and you spray a cool water on it, it could break something inside.  Read it in a thread somewhere here.
Reply #2February 09, 2005, 07:37:14 pm
rayrayworldwide
  • 7
« Reply #2 on: February 09, 2005, 07:37:14 pm »
I had this problem awhile back. There was a little bit of voltage backfeeding to the stop solenoid. I installed a spade connector on the wire leading to it and would pop the hood and disconnect it everytime I wanted to turn off the truck.
Turns out it was a faulty diode (the alternator light in the dash) that was causing the back feed. I installed a diode inline the alternator excite lead and haven't had a problem since.
Good luck
'82 Rabbit pickup TD
'83 Quantum TD
'86 Quantum Synchro (TD, someday?)
Reply #3February 10, 2005, 10:06:57 am
deepmud
  • 158
« Reply #3 on: February 10, 2005, 10:06:57 am »
Quote from: "Cheesetoast"
Can't hurt to be careful, but FWIW I have fully submerged the front end of my rig in water so cold you are unable to scream if you fall in, with no ill effects (knock on wood).
the 1.9TD/Suzuki w/big tires guy
visit Alaska @ www.alaska4x4network.com
