Author Topic: FOR SALE caddy rear axel lowering plates 2'to4' adjustable  (Read 3648 times)
August 03, 2007, 08:44:52 pm
blkboostedtruck
  • 1535
« on: August 03, 2007, 08:44:52 pm »
for sale caddy rear axel lowering plates $95.00 a pair! adjustable hight from 2' 2.5' 3' 4' there are 3 positions to choose from mild to wild! these plates are made from grade 50 certified steel! much stronger than the other one's from europe! it requires a secial drill and drillbit to penatrate a hole through the plates! these plates will not bend during corning ! and they will handle any load you throw in the back of your truck! they will not flex under any circumstances! they will space your spindal out 3/8' so if you have other rims and tires other than stock you might need further axel modification! (narrowing the axel 1')  or more for clearance from the tire and fender well arch and lip! I can provide that service if desired? well let me know who is interested because the grade 50 steel is limited and hard to obtain! as of now i nearly have the template completed and i have enough material to make up 3 other sets! these can also be reversed to raise the rear of the vehicle! can  possibly be used on any MK1or MK2 vehicle's?
 so act now while supplies are limited!! :roll:
         thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
