Author Topic: which headstuds? and 1.9 HG on solid lifter head?  (Read 2229 times)
August 03, 2007, 10:47:57 am
the4ork
  • 331
« on: August 03, 2007, 10:47:57 am »
if i can get the all metal HG on the solid lifter head i'll upgrade to headstuds, and finally run in the mid 30psi range instead of the mid 20psi range :)
added reliability and extra 10psi i thnk is a fair trade for a set of $150~ head studs and headgasket, so long as it doesnt cost an arm and a leg to get this gasket in there...
Reply #1August 03, 2007, 11:34:35 am
saurkraut
  • 904
« Reply #1 on: August 03, 2007, 11:34:35 am »
Head studs are always a good idea.  Remove your head once after intalling them and your $ ahead of the streach bolt schiza.
I think Tintin runs a metal head gasket on a mech block with a hunk of rubber sheet in the extra oil drain hole.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #2August 03, 2007, 03:02:08 pm
« Reply #2 on: August 03, 2007, 03:02:08 pm »
not to mention that it helps align keep the HG aligned so it doesn't move while you put the head on.
