Author Topic: Install needles(nozzels) from 1.9D to 1.9TD  (Read 4819 times)
February 08, 2005, 05:13:09 am
wasteland_TD
  • 20
« on: February 08, 2005, 05:13:09 am »
Hi guys.I want to change my needles(nozzles) on 1.9TD AAZ, but not the the complete injector.Every seller says to me that there is no separate needels for 1.9TD AAZ - only the complete injector, but this is too expensive for me.I asked in BOSCH autorized service and they affirmative that.
They said also, there is separate needels only for 1.9D motor.
I checked in ETKA about 1.9TD needle - there write - No longer Available!!!
Are these needels(1.9D) equals to needels from 1.9TD AAZ motor.
I found also there is separate needels from DTP - Diesel truck power i think.Is this brand good?
10x guys, sorry for my bad english
1.9TD AAZ
Reply #1February 08, 2005, 05:39:59 am
Smog
  • 160
Re: Install needles(nozzels) from 1.9D to 1.9TD
« Reply #1 on: February 08, 2005, 05:39:59 am »
Quote from: "wasteland_TD"
http://www.vwdiesel.net/phpBB/viewtopic.php?t=906
www.VEG-Injection-Service.com
1.6GTD nozzles (RA/SB )
1.9TD nozzles (AAZ )
0.205mm or 0.216mm TDI nozzles
TDI injection pump seal kit
IDI Pump shaft seal
Reply #2February 08, 2005, 06:03:14 am
wasteland_TD
  • 20
« Reply #2 on: February 08, 2005, 06:03:14 am »
10x smog but this don`t helps me much.....
1.9TD AAZ
Reply #3February 08, 2005, 06:09:11 am
Smog
  • 160
« Reply #3 on: February 08, 2005, 06:09:11 am »
do you want new AAZ nozzles or not ?
IDI Pump shaft seal
Reply #4February 08, 2005, 06:10:40 am
Smog
  • 160
« Reply #4 on: February 08, 2005, 06:10:40 am »
as North America never got the 1.9D engine in a car, nobody can help you.
IDI Pump shaft seal
Reply #5February 08, 2005, 06:20:30 am
wasteland_TD
  • 20
« Reply #5 on: February 08, 2005, 06:20:30 am »
yes i want new nozzles, but everyone told me that there is no original separate nozzles - only the complete injectors.
What brand are these nozzles from the link you gave to me.
I am from Europe
1.9TD AAZ
Reply #6February 08, 2005, 06:59:12 am
QuickTD
  • 1156
« Reply #6 on: February 08, 2005, 06:59:12 am »
Not sure where you are in europe but Helptoday Limited in the UK sells replacement nozzles for the 1.9TD. They have online ordering as well.
