Author Topic: 1.6 + VNT17 + 25psi + air/water = ?hp & ?tq ballpark fig  (Read 2843 times)
August 02, 2007, 10:24:49 pm
the4ork
  • 331
« on: August 02, 2007, 10:24:49 pm »
the engine is relatively stock except with a 100% ground up 0mile 0time rebuild....
giles pump /w ? injectors still
ceramic coated pistons .020 over
ceramic coated combustion chambers
ceramic coated turbine housing/manifold
ceramic coated compressor housing
moly lubed piston skirts and main bearings
oil shedding treatment on crank
VNT 17
custom locally manufactured short runner intake /w plenum
spearco air/water intercooler
2.5" side dump exhaust...
this is my plan right now, so far the motor is in the shop getting the block bored out, and pressure tested... and the head is in the middle of a full rebuild...
i have all the parts minus the vnt17 and the parts getting treated are sitting at the shop awaiting maintenance....
im hoping someone could give me a ball park figure of what kind of power i might be putting down at about 25psi.... wich i think will be the max i'll run since im not running studs and cant run an all metal headgasket :(
125hp? 160ft lbs of tq? if so thats like having the HP of a healthy 16v and the TQ of a Vr6  :twisted:
and this is the oldschool whip... EVIL
