Author Topic: disabling the stock bov and using aftermarket?  (Read 2513 times)
August 02, 2007, 07:50:14 pm
the4ork
  • 331
« on: August 02, 2007, 07:50:14 pm »
i have a blackstone intercooler with a 1st gen mitsu bov welded to it... can i use it? as a surge protection? how much psi do they hold w/o a vacuum signal? would i use a vacuum signal?
Reply #1August 02, 2007, 08:06:38 pm
OM617
« Reply #1 on: August 02, 2007, 08:06:38 pm »
The stock item is a pop off valve that relieves excess pressure as a safety device. You do not need any kind of BOV and trying to make one functional is 100% waste of time.
Reply #2August 02, 2007, 10:14:36 pm
the4ork
  • 331
« Reply #2 on: August 02, 2007, 10:14:36 pm »
dang i guess i'll keep this IC for my 8vT or sell it....
i also thought about running an air/air and air/water since i have a spearco awic and this small saab intercooler... might be a little overkill though, im going to be running about 25psi on a vnt17
Reply #3August 03, 2007, 06:05:05 am
saurkraut
  • 904
« Reply #3 on: August 03, 2007, 06:05:05 am »
You don't even need the stock one.  Back out the adjusting screw, drop a small cap screw down the hole and snug the adjusting screw against it.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #4August 04, 2007, 07:26:23 am
stewardc
« Reply #4 on: August 04, 2007, 07:26:23 am »
The nice aluminum plug with the green clamp is where the bov used to be on my 1.6TD. They were discontinued on later models.
