Author Topic: Bulletproof ???  (Read 4641 times)
August 02, 2007, 02:55:14 pm
vwwv
  • 25
Bulletproof ???
« on: August 02, 2007, 02:55:14 pm »
Just fired up my 90 1.6 na.  It had been sitting under my house for 2 full years although I did start it and run the engine for a few minutes last summer.  The battery is a VW OE from 2000 which has been on a solid state trickle charger for 3 years.  This engine is amazing.  There was no cranking - it simply started immediately.  The tires needed air but the A/C blew cold and the injector pump isn't leaking.  I bought this car as a back-up/parts car for my 86 Jetta but, so far, I've only needed to swap alternators.  I think I'm depriving someone of a good daily driver by hanging onto it?
1996 Passat tdi, 86 Jetta idi, 90 Jetta idi, 89 Suburban, 94 Polaris 4x4 ATV.
Reply #1August 02, 2007, 04:10:00 pm
Slave2School
  • 531
Bulletproof ???
« Reply #1 on: August 02, 2007, 04:10:00 pm »
I bet the pump will start leaking once you feed it a few tanks of ULSD :(
2002 ford focme wagon
Reply #2August 02, 2007, 04:24:35 pm
vwwv
  • 25
Bulletproof ???
« Reply #2 on: August 02, 2007, 04:24:35 pm »
Hey STS,  How's the trailer?  Yes, no doubt the IP will leak.  However, the "tonic" of auto trans fluid plus 2 stroke oil I used to solve my 86's IP leak hopefully will work for the 90?  I'm not really planning on driving this car - it's not registered nor insured at this time.  Don't know how long to expect the D2 to stay okay.  Guess I'm taking a chance not running it all out and putting in fresh ULSD?  Thanks for the response.   Paul
Reply #3August 02, 2007, 05:24:20 pm
Slave2School
  • 531
Bulletproof ???
« Reply #3 on: August 02, 2007, 05:24:20 pm »
If you are handy you can get the viton seals and redo the pump for very little $$$, I think th atmight have been what killed my 12mm pump off :( something leaking internally, hard to say it was so weak just a little pee dribble came out the pump lines.
The trailer is working great, I have th eborg cube back on top now instead of my cargo carrier so we can take the beast camping next week (weather permitting)
