Author Topic: 1.6L td injector options  (Read 10832 times)
Reply #15August 16, 2007, 03:40:52 am
Tony2ltr
  • 53
« Reply #15 on: August 16, 2007, 03:40:52 am »
I know a guy that put Cat injectors on his newer tdi, says he dyno's at over 400 lb of torque.  I have see the car (automatic) go.  He steps on the pedal, waits about 1.2 second for the boost, then the tires go uncontrollably up in smoke!  I can't verify the dyno numbers, he does some racing development for General Mess though.
Tony
92 Jetta Ecodzl/biodzl/WVO/meth-H2O turbspray
1969 Subaru 360 Sambar (converted to Electric)
1975 Chevy Cosworth Vega Turboed
1991 Toyota Pickup (megasquirted)
2004 POS Honda Civic (I'll never buy another)
2 cylinder Lister Petter diesel CO-Gen unit
Reply #16August 20, 2007, 07:56:20 am
Öl-Brenner
  • 11
Bosch Injector Nozzle part numbers
« Reply #16 on: August 20, 2007, 07:56:20 am »
Here is a list of nozzles I found,  Does anyone know how to decipher the type number?  the "0" I believe refers to the spray pattern angle which is 0 degrees. and the "S'" refers to pintle design.   :idea:
Type#      /      Bosch#
DN0SD193     /  0 434 250 063
DN0SD1930 /  0 434 250 092
DN0SD256   /  0 434 250 135
DN0SD259     /  0 434 250 117
DN0SD261     /  0 434 250 120
DN0SD263    /   0 434 250 125
DN0SD264    /   0 434 250 127
DN0SD265    /   0 434 250 128
DN0SD273     /  0 434 250 138
DN0SD274     /  0 434 250 139
DN0SD287+/  0 434 250 157
DN0SD288     /  0 434 250 150
DN0SD289     /  0 434 250 156
DN0SD292     /  0 434 250 154
DN0SD293     /  0 434 250 103
DN0SD294     /  0 434 250 155
DN0SD297     /  0 434 250 159
DN0SD299     /  0 434 250 160
DN0SD299A /  0 434 250 171
DN0SD299C /  0 434 250 193
DN0SD300     /   0 434 250 161
DN0SD301    /   0 434 250 162
DN0SD302     /  0 434 250 163
DN0SD302A /  0 434 250 175
DN0SD302B /  0 434 250 223
DN0SD306     /  0 434 250 167
DN0SD309     /  0 434 250 170
DN0SD310     /  0 434 250 897
DN0SD312    /   0 434 250 895
DN0SD313    /   0 434 250 174
DN0SD314    /   0 434 250 176
DN0SD315    /   0 434 250 177
DN0SD316    /   0 434 250 894
DN0SD318    /   0 434 250 191
DN0SD319    /   0 434 250 192
DN0SD320    /   0 434 250 224
DN0SD322     /  0 434 250 226
DN0SD327    /   0 434 250 234
Best Regards,
Noel
Impossible? Never!
'82 Vanagon Diesel 5cyl TD conv in '98
'86 Vanagon Syncro (soon to be TD)
'74 Merc 250/8 gasser CKD Japan
'86 Golf (Daily Driver)
Reply #17August 20, 2007, 11:04:52 am
vwmike
  • 1158
« Reply #17 on: August 20, 2007, 11:04:52 am »
Yes, the '0' is  the spray angle. You really want to stay with a nozzle that has the same spray angle or you're probably going to end up with atomization issues.
Reply #18January 01, 2009, 09:39:42 am
Tony2ltr
  • 53
« Reply #18 on: January 01, 2009, 09:39:42 am »
More on injectors from the Bosch injection pump book:
"abbreviated a bit...
1.Throttling pintle nozzles is used on swirl/prechamber/turbulance engines.
2.Injection is coaxial shaped jet of fuel
3.INjector Nozzle type (DN...SD) together with nossle holder type KCA with screw in thread.
4.normal version has M24X2 thread and an A/F dimension of 27mm.
5.injection nozzles have a needle Diameter of 6mm and spray angle of 0 degrees.
6.it is rarer to find defined 12 degree spray angle (in the DN 12 SD) for
7. for restricted cylinder head space more compact nozzle holder versions (e.g., KCE) are avaiable
8. The hole nozzles have needle Diams of 4 and 6mm (for DI engines)
9. the seat/hole nozzle is only available in size "P" version
10. opening pressure of holder and nozzle assembly (IDI) is approx 110-140 bar"
That is all I have found in the bosch book on VE pumps...
hope it helps some.
-Tony
Reply #19January 01, 2009, 03:59:08 pm
truckinwagen
  • 1895
« Reply #19 on: January 01, 2009, 03:59:08 pm »
I went with nozzles from a 80's diesel gmc with good results on a non modified motor. the nozzles were lots cheaper than vw or merc ones too, like ten bucks each.
they will flow way better too, so with a modified pump they should do even better
83 Opel Kadett Diesel
Reply #20January 01, 2009, 05:19:58 pm
Tony2ltr
  • 53
« Reply #20 on: January 01, 2009, 05:19:58 pm »
have you run it yet??
What kind of injectors were they? for a 6.5, 6.6?
-=Tony
