Author Topic: 5 sp. trans fill hole...where?  (Read 4624 times)
July 31, 2007, 01:43:38 pm
Trimster
  • 74
« on: July 31, 2007, 01:43:38 pm »
Where is the lube fill hole for the 5 speed trans?  I have a POS aftermarket manual and it does not even go there.
TIA
Bob
'83 Caddy, 1.6 NA Diesel, 5 speed, AC
2- motorcycles, 36' 5th wheel, sailboat, RC airplanes... to many interests, not enough time.
Reply #1July 31, 2007, 02:31:37 pm
blkboostedtruck
  • 1535
« Reply #1 on: July 31, 2007, 02:31:37 pm »
pull out the speedometer cable and fill it there! all you need is a larg phillips screwdriver and pull the cable and gear out! Fill up and reinstall cable and tighten philips screw!  very simple to do!
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2July 31, 2007, 02:42:07 pm
compu_85
  • 24
    • http://compu85.homeip.net
« Reply #2 on: July 31, 2007, 02:42:07 pm »
Yes, you can fill from there, but that won't let you know when the trans is 'full'.
The fill plug is on the front of the transmission, facing the radiator. It's a 17MM plug, just like the drain.
What year is your car? The early Mk2s have a different fill procedure then the later ones.
-Jason
99.5 Jetta GLS TDI. 219k miles
91 Jetta GL ECOdiesel. 400k miles+ Sold.
91 Mercedes 350SDL. 202k miles.
Reply #3July 31, 2007, 04:52:09 pm
« Reply #3 on: July 31, 2007, 04:52:09 pm »
Reply #4July 31, 2007, 05:50:49 pm
Trimster
  • 74
« Reply #4 on: July 31, 2007, 05:50:49 pm »
thanks. Mine is an '83. 5 speed, diesel. I think I got it now.
Bob
