Author Topic: Free Parts Rabbit in Indiana  (Read 3906 times)
July 31, 2007, 12:47:07 pm
dieselsnowmobile
  • 103
« on: July 31, 2007, 12:47:07 pm »
Here is a Green 81 Rabbit 1.6L Diesel 4 speed that is Free.  I got it for a parts car and used what I needed and then my daily driver Rabbit got in a wreck.  So, I do not need this Rabbit for parts any more and I would rather someone get some use of it rather than selling it for steel. I do not know much about the car other than it was parked in a barn when I got it and I parked in a barn until this past weekend.  It had about 160,000 miles on when I got it.  I thought about getting it going but it was going to cost more than I wanted to spend.  I did have it firing but it was floored and barely idling because I believe it was sucking air.  In the mean time, I took the starter off, took the pump off to send in as a core, and I took the fronts tires off to have some spare rims.  I also took the injector lines to have a spare.  As you can see, I also took the instrument panel out since my odometer broke.  I also took the washer fluid tank, the head oil pressure sensor, and head lights.  The driver window crank is broken but the window is still there.  The car is located 5 miles south of Kokomo, IN 46901.  As you can see, you will need to trailer it and you may need to bring two front tires to get it on your trailer.  There is minor rust on the car and there is a picture with the worst body rust next to the antenna.  The windshield is cracked.  Also, since it was stored in a barn, mice might be in it.  I put mice poisen around it.  If you are interested, please PM me and I will give you contact details.  Obviously there is no warranty nor any guarantee the car will start when fixed nor a guarantee it will have the part you may need.  I do have the title it.  Pictures are below.
'89 1.6L NA Diesel Jetta (469,100 mi) w/ Rabbit Engine (242,500 mi)
Reply #1July 31, 2007, 02:01:54 pm
foxracer1
  • 991
« Reply #1 on: July 31, 2007, 02:01:54 pm »
I'm interested pm sent
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #2August 21, 2007, 07:47:40 pm
dieselsnowmobile
  • 103
« Reply #2 on: August 21, 2007, 07:47:40 pm »
Gone.
