Author Topic: Removing Engine  (Read 4104 times)
July 29, 2007, 07:04:25 am
Riverfurm
  • 122
Removing Engine
« on: July 29, 2007, 07:04:25 am »
Getting close to my engine swap on my 86 Golf. The Bentley manual states to remove the front apron and rad. support. Tilt the engine and trans. and remove from the top. I have seen other people remove the engine from the bottom.
  I will be doing this engine swap at home, so I have no lift. But I do have a hoist mounted on a beam ( I've used it to pull big blocks to lawn tractor engines so it's very strong). It seems easer to me to pull it out through the top.
  Is it :?:  :?:  :roll:
The engine coming out is a 1.6 na the one going in is a 1.6 turbo with Giles IP, PP down pipe, and boost bumped up.
It is a manual trans car with AC and I don't want to disscharge the AC system.
Thanks
Riverfurm on the Delware
86 Golf 1.6 Turbo, Giles IP, Pass 3"dp and 3"ex
Fleet of Ford Diesels and Case Equipment
Reply #1July 29, 2007, 08:06:12 am
Black Smokin' Diesel
  • 656
Removing Engine
« Reply #1 on: July 29, 2007, 08:06:12 am »
You can get it out through the top if you remove the hood, it might be a PITA though. If you remove the AC compressor from the engine you can avoid discharging the AC (like the bentley says).
Getting the engine out through the bottom is only good if you remove the whole front suspension too (subframe, control arms, shocks...).
Reply #2July 29, 2007, 09:19:48 am
Removing Engine
« Reply #2 on: July 29, 2007, 09:19:48 am »
I never remove the hood on mk2s but I do take off teh front apron (not the bumper though, just the grill and rad support)
Reply #3July 29, 2007, 10:39:24 am
Mk2Fanatic
  • 93
Removing Engine
« Reply #3 on: July 29, 2007, 10:39:24 am »
Every swap I've done at home was as follows:
              remove bumper, grille, rad support
              swing ac stuff up and out of the way over p-side fender.
              using a crappy tire appliance cart the fold down style roll it under             motor and trans
remove front tires lower car onto 16x8 cinder blocks 1 on each side
unbolt axles, exhaust ahead of cat or resonator
undo shifter linkage and electrical connectors and roll the cart out with motor and trans on appliance cart.  cart is strong enough to double as a tear down reassembly stand.
reverse procedure to install.
6hrs in and out including new clutch axle seals, TO bearing swapping flywheel etc
5 VW's: Mojave beige (LE1N) Mk1 rabbit 16V; Mk2 Jetta wolfsburg TDI conversion;Mk2 1.6TD Twin Charged Project; 86Mk2 1.6TD Jetta (daily); 1988 1.6NA Jetta; 1994 Passat 1.9TD donor
Reply #4July 29, 2007, 11:45:08 am
larry104
  • 200
Removing Engine
« Reply #4 on: July 29, 2007, 11:45:08 am »
Quote from: "Mk2Fanatic"
PLEASE DO NOT USE CINDER BLOCKS! They have been known to crumble and give no warning. Use wood or, better yet, jack stands to support a car.
Reply #5July 29, 2007, 12:35:25 pm
Removing Engine
« Reply #5 on: July 29, 2007, 12:35:25 pm »
i was able to remove a motor and leave the a/c system untouched (the lines were bent to their limit at times though  :lol:)
Reply #6July 29, 2007, 02:50:17 pm
Mk2Fanatic
  • 93
Removing Engine
« Reply #6 on: July 29, 2007, 02:50:17 pm »
Quote from: "larry104"
I understand what you are saying about the crumbling part.  The two that I use at home have been filled with concrete in the 3 openings.  My Ex wife's Father is a structural engineer and advised me that if filled they will pose no risk of collapse.  They were purchased new for one purpose and one purpose only.  As an alternative, jackstands or 8" square cut logs or 4 2x8's screwed together will also work.
Reply #7July 29, 2007, 03:20:38 pm
Removing Engine
« Reply #7 on: July 29, 2007, 03:20:38 pm »
its only easier to go out the bottom on mk1s
Reply #8July 30, 2007, 02:35:41 pm
bevboyy
  • 200
Removing Engine
« Reply #8 on: July 30, 2007, 02:35:41 pm »
I just removed the hood, and put the front end on jack stands. Disconnected axles. Removed the rad, and ac - which has been pitched..disconnected all wiring. Used shop crane and voila..engine out....
1987 Jetta Mk2 - daily driver, MZ 1.8 goodness. TJ auto trans..
Gone but not forgotten:
1985 Mercedes 300d Turbo
1987 Olds Delta 88 Royal Brougham
1992 Mercedes 190e 2.3
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1979 Mercedes 300D (non turbo)
1977 BMW
Reply #9July 30, 2007, 03:38:52 pm
Riverfurm
  • 122
Removing Engine
« Reply #9 on: July 30, 2007, 03:38:52 pm »
If it wasn't for the AC, (I need an AC recycle machine)I would just remove the cooling fan. It does not look that tight. But I think I'll take the rad. and support out (see how much room for an intercooler). I have been checking around for an exhaust system for the 3" PP downpipe but have not found one yet. I guess I'll have to have a custom one made or fab one up myself.
I have plenty of jack stands and jacks.
Reply #10July 30, 2007, 05:58:43 pm
2mn2
Removing Engine
« Reply #10 on: July 30, 2007, 05:58:43 pm »
I removed the engine from the top on my rabbit. I used a tilt bar and a shop crane. It came out easy and no complications
Reply #11July 30, 2007, 06:07:59 pm
Removing Engine
« Reply #11 on: July 30, 2007, 06:07:59 pm »
I'm also a fan of going out to top for all my cars. I went out the bottom once on a rabbit and it's pretty much just as much work. I find removing the oil fitler will make it easier
Reply #12July 30, 2007, 11:38:38 pm
boosted_diesel_84
  • 216
Removing Engine
« Reply #12 on: July 30, 2007, 11:38:38 pm »
i just removed mine out the bottom, with gearbox attached, all together, almost 4 hours, i think its a lot easier to drop it out the bottom than to raise it, not to mention safer, you dont have a massive chuck of metal swinging 10 ft. in the air.
.0020 over block,balanced,blueprinted,8lb flywheel,Stage 2 clutch,ported and ceramic coated head manifolds,turbo,pistons, SS valves, PP 2.5in DP,Intake, 3" ex.GTD nozzles, Built pump, windage tray,36mm pump,ARP Studs.etc.My build thread http://www.vwdiesel.net/forum/index.php?topic=15461.0
