Author Topic: Wheel Spacers  (Read 4423 times)
July 28, 2007, 08:38:26 am
WagonMan
  • 9
Wheel Spacers
« on: July 28, 2007, 08:38:26 am »
I am looking to purchase wheel spacers for my 03 jetta wagon tdi. Can anyone tell me what is a good size to get and possibly some pics so I can actually see for myself. Thanks Guys.
Reply #1August 14, 2007, 04:10:40 am
Jetta Fan
  • 286
Wheel Spacers
« Reply #1 on: August 14, 2007, 04:10:40 am »
I'm contemplating the same thing for my 97 Jetta. A local shop suggested 8mm to 10mm spacers. They said any larger than that and I'd have to switch over from bolts to studs and might run into clearance issues.
1997 Jetta 1.9TD AAZ
Reply #2August 20, 2007, 11:55:23 am
Peter
  • 136
Wheel Spacers
« Reply #2 on: August 20, 2007, 11:55:23 am »
Quote from: "Jetta Fan"
..for some shop to say you will be OK with extending your wheel without making any changes is like letting someone else playing with your life ...(the new wheel will probably bolt up but not safely.)...manufactures don't give any extra spare length to the bolt or stud...10mm spacer means a 10 mm longer bolt or screw in stud to give you the same safety margins as Stock
Reply #3August 21, 2007, 07:40:57 am
Jetta Fan
  • 286
Wheel Spacers
« Reply #3 on: August 21, 2007, 07:40:57 am »
I should clarify....with the 10mm spacers, I would have to run a longer bolt. If I go larger than a 10mm spacer, they told me I would have to switch the car over to studs.
They did not tell me I could stick with my stock bolts. Sorry if it sounded that way.
Reply #4August 21, 2007, 08:52:19 am
Peter
  • 136
Wheel Spacers
« Reply #4 on: August 21, 2007, 08:52:19 am »
thanks for clearing that up
Reply #5August 21, 2007, 10:49:02 am
Jetta Fan
  • 286
Wheel Spacers
« Reply #5 on: August 21, 2007, 10:49:02 am »
No problem. Wouldn't want to mislead anyone, especially where safety is concerned.
