Author Topic: HURRY!! How to tight head bolt for 1.6 TD !!  (Read 9478 times)
Reply #15July 29, 2007, 05:35:00 am
Audi80
« Reply #15 on: July 29, 2007, 05:35:00 am »
Are you sure? Do you have aftermarket head?
1,9 HG will fit directly to engines with hydraulic lifters. You can easily make it fit to solid lifter engine too, just block the extra hole with piece of rubber.
There is original turbo engines with solid lifters from factory.
Reply #16July 29, 2007, 09:11:58 am
cableroy
  • 19
« Reply #16 on: July 29, 2007, 09:11:58 am »
Quote from: "Audi80"
Hydraulic does not have visible springs right? they got this call "pusher" above/around the spring right? Thats what i have, and the guy at the shop came with a head gasket that was the same as my old gasket and he told me that this one was before 86 or something.
Reply #17July 29, 2007, 12:42:09 pm
« Reply #17 on: July 29, 2007, 12:42:09 pm »
i had a factory original 1.6TD mech engine in an 86.  last year that they sold mech engines.  I must say that car had some serious low end grunt.  wasn't tuned for revving, but it could haul a car full of 'heavy set' people(5x200lbs or more) and still accelerate as if it was empty, but once 3k rpm hit, there was no balls, so next gear and away she went.  :D  i still miss that car!!!
you can't use a hydraulic head on a mech block as far as i know.
Reply #18July 29, 2007, 01:33:33 pm
cableroy
  • 19
« Reply #18 on: July 29, 2007, 01:33:33 pm »
i got a picture I'm gonna upload witch i took with the 1.9 TD gasket and the one i had, i'll try tomorrow.
Reply #19July 29, 2007, 01:46:10 pm
Black Smokin' Diesel
  • 656
« Reply #19 on: July 29, 2007, 01:46:10 pm »
Look at this pic, see the big hump in the middle between the injectors #2 and #3? If you look to the left, there's another smaller hump between injector 1 and 2. Every hydraulic head has these two humps. If there's only one big hump in the middle, it's a mechanical head.
Reply #20July 29, 2007, 01:53:15 pm
Audi80
« Reply #20 on: July 29, 2007, 01:53:15 pm »
Mechanical AMC aftermarket heads have two humps. The smaller one is not drilled.
The lifter is above/around valve springs. Mech lifter has separate adjusting blocks between lifter and cam.
Reply #21July 30, 2007, 10:10:44 pm
cableroy
  • 19
« Reply #21 on: July 30, 2007, 10:10:44 pm »
Quote from: "Black Smokin' Diesel"
Yes looks like the one i got, but on the cam shaft bearings you have 3 bolts in the center, i don't have those...
Reply #22July 31, 2007, 02:44:47 pm
  • 656
« Reply #22 on: July 31, 2007, 02:44:47 pm »
Quote from: "cableroy"
That's because it's a picture of a 1.9TD head. 1.6TD is pretty much the same except for those studs and intake/exhaust ports.
Reply #23July 31, 2007, 03:04:45 pm
cableroy
  • 19
« Reply #23 on: July 31, 2007, 03:04:45 pm »
ok i see!
But hey listen up :)
i put my engine back, but apparently when i tried to start the engine the wheel on the camshaft have moved a little because of not tightening it enough, so now my valves has hit the pistons several times, but since the valves goes straight down to the pistons, any of you got experience if i can just time it again and run? Or do you think piston/valves are broken now, i'm not taking it apart to inspect, i'll rather just change the engine to a real 1.6 TD with diesel pump with "UFO"...
Reply #24August 01, 2007, 06:50:33 am
Benjamin
  • 485
« Reply #24 on: August 01, 2007, 06:50:33 am »
is this a 1.6D or 1.6TD head?
mechanical or hydro?
thanks!
Greetz, Benjamin
Must make +250hp
Reply #25August 01, 2007, 09:08:49 am
Audi80
« Reply #25 on: August 01, 2007, 09:08:49 am »
1,6 hydro
Reply #26August 01, 2007, 09:41:56 am
cableroy
  • 19
« Reply #26 on: August 01, 2007, 09:41:56 am »
Finally took some pics of my engine,, i checked the valves and the exhaust valves hit the pistons, but they where ok....
Hope someone can identify witch engine i got, gasket i need to use vas earlier than 86....
Reply #27August 01, 2007, 12:38:29 pm
Audi80
« Reply #27 on: August 01, 2007, 12:38:29 pm »
You have mech block, head and lifters.
Reply #28August 01, 2007, 01:16:21 pm
« Reply #28 on: August 01, 2007, 01:16:21 pm »
Looks like your intake valves on 1 and 4 touched down for sure... did it warp the valve(s) ??
Reply #29August 02, 2007, 03:46:09 am
cableroy
  • 19
« Reply #29 on: August 02, 2007, 03:46:09 am »
Quote from: "Vincent Waldon"
They look ok, and passed my leak test... :)
