Author Topic: SOLD: 1.9TD head  (Read 9526 times)
July 24, 2007, 02:43:38 pm
Black Smokin' Diesel
  • 656
SOLD: 1.9TD head
« on: July 24, 2007, 02:43:38 pm »
SOLD SOLD SOLD
It comes with the injectors, intake manifold (D ports), camshaft & sprocket and valve cover. I wouldn't use those injectors without having them rebuild as I have no idea how much mileage they have and how long they were exposed to air. There are the usual cracks between the valves and the cylinder #2 valves have a small crack between the pre-cup and valve (see pics). The head is still useable. The engine I pulled it from had a good headgasket (no leaks) and I really doubt the head is warped. Having it resurfaced would be a good idea though as there is a fair amount of crud cooked on the gasket surface.
I will NOT part the head for any reason, I'm selling it as seen in the pictures. I cleaned it up a bit but I'm leaving the rest to the buyer.
The cam is in perfect shape, there is no rust on it as the pic suggests, it's just a weird reflection on it.
All the exhaust studs are there but the upper left and right exhaust studs still have their nuts because they are stuck in rust. The washers you see on these two studs are the washers used between the manifold and nuts (locking copper nuts, not included).
#2 with the small crack. It hasn't reached the valve. You can have it welded and have the pre-cup hole and gasket surface surfaced.
Other stuff
-Three standard size 1.6TD pistons with pins, 20$ each plus shipping
Reply #1July 24, 2007, 05:21:04 pm
foxracer1
  • 991
SOLD: 1.9TD head
« Reply #1 on: July 24, 2007, 05:21:04 pm »
Man if i didn't have a dirt bike needing a rebuild. I would be all over that head/intake. I need to pick one hobby.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #2July 24, 2007, 06:56:15 pm
  • 656
SOLD: 1.9TD head
« Reply #2 on: July 24, 2007, 06:56:15 pm »
Quote from: "foxracer1"
Eh tell me about it. I picked up this head because I need one for my project but I realized my budget didn't allow me to even buy it in the first place, let alone rebuild it :?
Reply #3July 26, 2007, 09:25:56 pm
  • 656
SOLD: 1.9TD head
« Reply #3 on: July 26, 2007, 09:25:56 pm »
Bump added some "new" stuff
Reply #4July 27, 2007, 11:05:30 am
Turbinepowered
  • 1206
SOLD: 1.9TD head
« Reply #4 on: July 27, 2007, 11:05:30 am »
Okay, I'll bite; can I get a shipping quote for 29670 for the K03 and manifold?
Reply #5July 27, 2007, 02:24:27 pm
  • 656
SOLD: 1.9TD head
« Reply #5 on: July 27, 2007, 02:24:27 pm »
Quote from: "Turbinepowered"
I'll have your quote this weekend.
Reply #6July 27, 2007, 03:10:00 pm
Turbinepowered
  • 1206
SOLD: 1.9TD head
« Reply #6 on: July 27, 2007, 03:10:00 pm »
Quote from: "Black Smokin' Diesel"
Works for me. Just checked over the finances; if you haven't already sold them, mind adding the TD oil pan and return line to the package and quote?
Reply #7July 27, 2007, 04:34:26 pm
  • 656
SOLD: 1.9TD head
« Reply #7 on: July 27, 2007, 04:34:26 pm »
Some guy told me he wanted them but I haven't heard from him since. I'll get you two quotes, one with and one without.
Reply #8July 29, 2007, 04:07:49 pm
  • 656
SOLD: 1.9TD head
« Reply #8 on: July 29, 2007, 04:07:49 pm »
Got your quote, PM sent.
Reply #9August 04, 2007, 08:18:39 pm
  • 656
SOLD: 1.9TD head
« Reply #9 on: August 04, 2007, 08:18:39 pm »
New price on the 1.9TD head, 210$ instead of 240$, just for you guys though, still 240$ on the other forums I posted it.
Reply #10August 07, 2007, 03:25:29 pm
  • 656
SOLD: 1.9TD head
« Reply #10 on: August 07, 2007, 03:25:29 pm »
Bump, come on you know you want it!
Reply #11August 26, 2007, 09:31:40 am
  • 656
SOLD: 1.9TD head
« Reply #11 on: August 26, 2007, 09:31:40 am »
Bump, buy some stuff people :lol:
Reply #12August 31, 2007, 09:19:56 pm
tecgod13
  • 2
SOLD: 1.9TD head
« Reply #12 on: August 31, 2007, 09:19:56 pm »
Will the oil return line fit on a 1.6TD in an 84 Jetta?
If so I could use it, mine looks like its falling apart.
Also any pictures of those underdash trays?
Reply #13August 31, 2007, 10:40:46 pm
  • 656
SOLD: 1.9TD head
« Reply #13 on: August 31, 2007, 10:40:46 pm »
Quote from: "tecgod13"
Well according to vagcat.com, both oil return lines have the same part number but I can't be sure it'll fit.
The black tray is most likely sold at this point. Here are pics of the brown tray
Reply #14September 04, 2007, 05:53:19 pm
tecgod13
  • 2
SOLD: 1.9TD head
« Reply #14 on: September 04, 2007, 05:53:19 pm »
I guess its worth a shot.
Can you get me a quote for the oil line and the programmable wiper relay shipped to Ludlow, MA 01056 ?
