Author Topic: 1.6TD nominal oil temp  (Read 6436 times)
July 22, 2007, 10:09:11 pm
zagarus
  • 619
« on: July 22, 2007, 10:09:11 pm »
just curious if anyone knows or has a link to info regarding operating temperatures for oil and possibly coolant.  Im just curious because my cars oil temp is running between 225-240F even when just cruising along on the highway boosting about 2psi at 110km/h.
Reply #1July 24, 2007, 04:09:04 pm
koen GTD
  • 9
« Reply #1 on: July 24, 2007, 04:09:04 pm »
normal driving   80°C
not normal driving (usual  :lol: ) 100°C
measured at oil filter
1.6td  k 24  @ 20PSI
109Hp @ 5400RPm
tip; in europe, the  mk1 gti (also scirocco)  has an very efficient oil cooler with an thermostate that opens at 95°C
also some 2.4 td vw/volvo engine have it
Diesel Boost
Reply #2July 24, 2007, 04:17:28 pm
bevboyy
  • 200
« Reply #2 on: July 24, 2007, 04:17:28 pm »
Now that's an oil cooler...
1987 Jetta Mk2 - daily driver, MZ 1.8 goodness. TJ auto trans..
Gone but not forgotten:
1985 Mercedes 300d Turbo
1987 Olds Delta 88 Royal Brougham
1992 Mercedes 190e 2.3
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1979 Mercedes 300D (non turbo)
1977 BMW
Reply #3July 24, 2007, 05:16:26 pm
zagarus
  • 619
« Reply #3 on: July 24, 2007, 05:16:26 pm »
my oil temp sensor is on the side of the head while my pressure sensor is on the oil filter, should i have them the other way around?
Reply #4July 24, 2007, 05:23:28 pm
foxracer1
  • 991
« Reply #4 on: July 24, 2007, 05:23:28 pm »
I need that setup!!!!!!
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #5July 24, 2007, 07:48:08 pm
IRoll
  • 25
« Reply #5 on: July 24, 2007, 07:48:08 pm »
Quote from: "zagarus"
I am no expert, but I would assume you should switch them. It just makes more sense to me that way.
-E
How fast?
As fast as it takes.
Reply #6July 24, 2007, 09:35:04 pm
zagarus
  • 619
« Reply #6 on: July 24, 2007, 09:35:04 pm »
i think im going to tomorrow, but wouldnt you still say 115C at the head is pretty hot for oil?  isnt that like beyond safe temperatures?  or are all the measurements and specs for oil temperature taken at the oil filter flange?  i have no idea, i just assumed getting the oil temp reading from the head would be the best as it would tell me whats going on closer to the pistons and combustion.
Reply #7July 24, 2007, 09:37:29 pm
« Reply #7 on: July 24, 2007, 09:37:29 pm »
My oil temp gauge is on the head and I get 130C some days if I'm really pushing hard... never ever seen more than that.  Usually it hovers around 110ish during *normal* driving
Reply #8July 24, 2007, 09:45:46 pm
zagarus
  • 619
« Reply #8 on: July 24, 2007, 09:45:46 pm »
so my 95-115 is normal for a constant temp. I live in a hilly city so i know itll climb when i go up hills. The most ive seen it go was about 245-250F so like 117-120C.   So im in no danger then?
Reply #9July 25, 2007, 03:42:05 pm
« Reply #9 on: July 25, 2007, 03:42:05 pm »
For conventional oil, I have heard that for every 10 degrees you go over 250, you cut it's life in half, so getting to 250 isn't doing your oil any favors. Synthetic withstands much higher temps, which is why I'm running it since my coolant gets as hot as your oil sometimes. :cry:
Reply #10July 25, 2007, 11:40:46 pm
carrizog60
  • 978
« Reply #10 on: July 25, 2007, 11:40:46 pm »
i also have a oil cooler on my car but i left the oem water/oil in place also.
should be best to delete the water/oil unit and just go with the air/oil unit?tlow temperature wise?
its a MKI gti oil cooler with an adapter plate with thermo from mocal.
Portugal
